Old 09-07-2012, 12:20 PM   #127
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Won't the car hit the speed limiter in 4th?
Anyway shouldn't matter, it's all calculated numbers anyway. The only true measure of power is directly off the crankshaft. The gearbox is simply a tourque multiplier to allow the car to move at different speeds.
Old 09-07-2012, 12:28 PM   #128
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Thanks for setting me straight, Blue.
The engine hit the limiter in 4th with both manifolds.
It just took 30 seconds to get there.
Old 09-07-2012, 12:41 PM   #129
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wicked!!!!!
Old 09-07-2012, 01:17 PM   #130
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I hit the limiter for 4th right now...guess boost helps a LOT
Old 09-07-2012, 01:20 PM   #131
I think we got enough accuracy with 3rd gear pulls to be able to compare the stock part to the part we made. That's all I was after. If I just wanted the highest number possible, I would have booked a more forgiving dyno machine.
On my car, we've done 4th gear pulls -- no speed limiter, rev limiter programmable, and 3rd gear goes by pretty quickly. I did have an assumption then that 4th gear would be better for all cars, but I think I was incorrect about that being a hard rule.
Old 09-07-2012, 01:40 PM   #132
fnkngrv
fnkngrv's Avatar
^ looks like that is the case. As previously stated a part like this could really be a crapshoot and in this case it was a positive result even on a car with limited mods so that is a big plus.
Old 09-07-2012, 02:52 PM   #133
Forgot to shout out to the dyno shop - thank guys!
KT Motoring
10149 Canoga Ave. Unit 1
Chatsworth, CA 91311
747.224.0237
Old 09-07-2012, 04:21 PM   #134
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Any chance of a 1ZZ version with nitrous ports?
Old 09-07-2012, 04:30 PM   #135
thefalls
Drives: Axio GT
^ I sure want to or with a Zage kit at low boost.
I think I'll throw one on my car with a 70mm TB and see what it pulls too. Let's see what 25 psi does to it.
This is going to be interesting!
Of course there will be gains over the plastic one.
Well lets find out with the boosted motors.
I better start saving!
thefalls is offline   Reply With Quote
Old 09-07-2012, 04:49 PM   #136
chaditotx
Drives: 2007 3dr hb 5sp
Yeah I observed that too on the 1NZ, perhaps it's a feature from Toyota engineers, prevent detonation in the worst possible conditions?
Thats wild. As piston speed increases the likelyhood of autoignition decreases... maybe the ecm is throwing a lot of advance at that part of the curve too.
chaditotx is offline   Reply With Quote
Old 09-07-2012, 05:42 PM   #137
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
I'm ready to buy! I can't wait to see these go on sale.
4/20 NEVER FORGET is offline   Reply With Quote
Old 09-07-2012, 08:22 PM   #138
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
My timing on the top end is around 24* iirc....stupid low timing if you ask me.
I used to run one oy old malibus at 15* initial and 44* total...ran awesome too
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-07-2012, 08:30 PM   #139
Bluevitz-rs
Yeah the timing backs way off as RPM climbs. An old acquaintance put a programmable ecu on his echo and said he added 20° of timing to the top end and gained a whack of top end power with nothing more than the regular boltons.
Old 09-07-2012, 08:37 PM   #140
chaditotx
Sometimes I miss my carburetors... I wonder if there is a way to adjust the position of the crankshaft position sensor and just have the damn thing advanced 2 degrees from the get go
Old 09-07-2012, 08:41 PM   #141
Bluevitz-rs
Theres absolutely no way to move the sensor but you could have a new pickup wheel made up or try and rotate it somehow.
Old 09-07-2012, 11:17 PM   #142
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
g.q.vios is offline   Reply With Quote
Old 09-09-2012, 04:59 PM   #143
chaditotx
I'm feeling a bit more coming from that manifold with an exhaust, header and a cold air.... I am really excited to see what it does when it breathes on both ends.
Old 09-10-2012, 12:39 PM   #144
malibuguy
Obsessed with 1.5L
i was watching my scangauge this weekend...up in the top end in boost my timing is down to around 15*...i could probably run diesel in this thing
-96 Tercel 4dr
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 02:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 07:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 12:58 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 09:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-14-2008 12:26 AM
