Old 10-15-2012, 11:33 PM   #19
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
OK my bad! Sorry Mason.
So you're saying to remove the pressure sensor and replace it with the 1/4-1/8" fitting for the vacuum line from the live unit.
Where does the sensor go to? Are there other orifices?
Old 10-15-2012, 11:36 PM   #20
The pressure sensor is for oil pressure. You would mount that somewhere where you can see the oil pressure, like at the filter sandwich adapter that they mention in the instructions.
Old 10-15-2012, 11:42 PM   #21
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Ahh. I see, so he would need that (optional) adapter for the oil pressure sensor.
Sorry, I thought that picture was of the block that the pressure sensor was in.
Here is LtNoogies thread which might help?
Old 10-16-2012, 12:12 AM   #22
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Thanks for the link/info!
Old 10-16-2012, 12:57 PM   #23
47_MasoN_47
I looked through that thread but didn't notice it, does anyone know what the thread pitch of the Yaris oil filter is so I get the right sandwich adapter?
Old 10-16-2012, 02:13 PM   #24
47_MasoN_47
From looking around it looks like 3/4 unf-16?
Old 10-16-2012, 02:27 PM   #25
^ I have them in stock
I am not using one though, so I know it's not required to install an oil pressure gauge.
Old 10-16-2012, 02:54 PM   #26
Since you are running a standalone, are you running an oil pressure sensor in place of the stock oil pressure switch?
Old 10-21-2012, 01:09 PM   #27
47_MasoN_47
Ok so I got a sandwich adapter for the oil filter, moved all the sensors to the right places, etc. I have the "live unit" tied up by the ECU. What would be the best place to tap into for power for it? The guy in the other thread powered his gauges from inside the car, but I'd rather just power it from the engine bay fuse box if I can.
Old 10-21-2012, 09:16 PM   #28
you can grab constant power from the under-hood fuse box, but not ignition switched power.
Old 10-21-2012, 09:25 PM   #29
47_MasoN_47
Shaft. So to get ignition switched I'll just have to plug into that panel under the dash and route it back through the firewall? Will it be OK to ground it to the frame or do I need to run the ground back through to there also?
Old 10-21-2012, 09:30 PM   #30
Chassis grounding is fine. You can go through the little grommet that is right above the ECM for making your way into the cabin.
Old 10-22-2012, 03:27 PM   #31
47_MasoN_47
I've been using the one that the AC pipes go through over on the driver's side, mostly just because that's the only one I could see haha. I have the first gauge in and connected. All that's left is power, I have the wires in place for that but left my sockets at home so I couldn't get the ground connected during my lunch break.
Upper driver's side glove box w/ holes cut for gauges PETERPOOP Items for Sale by private party 9 07-31-2011 08:21 PM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-20-2009 12:40 AM
My new gauges set up PETERPOOP Cosmetic Modifications (Exterior/Interior) 30 04-19-2009 09:50 PM
Mechanical vs Electric Gauges? PETERPOOP Forced Induction Forum 13 04-06-2009 02:25 AM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 03:42 PM
