Old 10-28-2012, 04:58 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
drilled the wrong hole, what now?
i was installing a switch today and i didnt realize there's a metal piece behind it and I couldn't put the switch it. I am now left with a hole like this. Any idea what i should do to cover it up? how much is it if I buy the whole piece?
thanks
caineroad is offline   Reply With Quote
Old 10-28-2012, 06:24 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Old 10-28-2012, 10:16 AM   #3
Ouch. That lower dash assembly is a good junkyard find part. The other option would be to cover that little section with some adhesive vinyl.
Old 10-28-2012, 10:36 AM   #4
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
nah...if i was you i would buy a piece of plastic and fix it on it....
dindy is offline   Reply With Quote
Old 10-28-2012, 10:40 AM   #5
GTBaker
GTBaker's Avatar
Drives: 2012 Yaris LE
GTBaker is offline   Reply With Quote
Old 10-28-2012, 11:34 AM   #6
NEexpat
Drives: 2009, auto, 4dr LB
Finish and clean up the cut, find a switch that will fit the opening, gut it flat, (dremel it shallow so it fits)
install.
Serves no purpose other than camouflage.
NEexpat is offline   Reply With Quote
Old 10-28-2012, 11:38 AM   #7
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Best solution eva
Originally Posted by sw07gt
Old 10-28-2012, 12:35 PM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
install.
^THIS^ or find a blank that will fit.
Old 10-28-2012, 01:14 PM   #9
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
The plastic jack holder under your driver's seat should be the same color. Just cut a small rectangle a little larger than your unfortunate plastic surgery malpractice error and glue it over. It shouldn't be that noticeable.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 10-28-2012, 01:19 PM   #10
Kar98
Drives: 2011 Scion tC
Kar98 is offline   Reply With Quote
What's this hole in my air intake? Yury General Yaris / Vitz Discussion 22 01-23-2012 08:00 PM
Big BAD-ASS Brakes...Drilled xbgod Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 09-15-2010 08:54 PM
Drill hole in Driver's glovebox? Revsson In Car Entertainment + Electronics (audio / video / alarm) 6 07-05-2010 06:26 PM
Screwdriver popped a hole behour General Yaris / Vitz Discussion 5 01-30-2010 09:05 PM
Spoiler installation gone wrong jinxor Cosmetic Modifications (Exterior/Interior) 7 03-24-2009 01:13 AM
