Old 12-29-2012, 03:03 AM   #127
bronsin
bronsin's Avatar
Can anyone publish a link to the TSB?
Thanks!
Old 01-02-2013, 10:24 PM   #128
Hershey
Got the notice earlier .
Old 01-08-2013, 12:32 PM   #129
narly charley
Drives: 2010 Yaris "L" 5 Speed
Just got my letter in the mail today. They are doing a 100,000 mile or 7 year coverage for the bolt. I'll take it in when I see that it's starting to go. Damn this salt!!
narly charley is offline   Reply With Quote
Old 01-08-2013, 06:39 PM   #130
FrankM
Drives: 2008 toyota yaris/2000 mr2
i hope it dont snap off when i try to take it out to look at it , if it looks good should i leave it alone ? Thank Frank
FrankM is offline   Reply With Quote
Old 01-08-2013, 06:59 PM   #131
auxmike
auxmike's Avatar
I changed out both of mine. They weren't that bad. They did have what looked like mulch on them. I think they get like 118 ft lbs. pretty good workout while laying on ones back!
Old 01-08-2013, 09:48 PM   #132
nookandcrannycar
It is 19mm. You can remove it and reinstall it without issue.
Old 01-08-2013, 10:02 PM   #133
nookandcrannycar
Old 01-10-2013, 03:23 PM   #134
Don777
Drives: yaris hatch
yaris lower control arm bolts
the bolts rust off at the head
Canadian tsb
sample invoice for repair I found on net
I have been spraying 2 or 3 + times a year,, the whole area with rust check, spraying in every hole in the suspension and sub frame
2006 yaris HB 125,000km, so far so good,, Ontario Canada
I would not recommend trying to get the bolts out if they are old or already starting to rust as the head would probably snap off
File Type: jpg 036c8ee2-1c01-102f-bffb-bccabd56764er.jpg (64.6 KB, 393 views)
File Type: jpg 465f4a64504452546277694b6355386b516777-450x450-0-0.jpg (11.3 KB, 390 views)
Don777 is offline   Reply With Quote
Old 01-10-2013, 04:12 PM   #135
Don777
Drives: yaris hatch
Yariscontrol arm bolts
here's what I have re bolt corrosion images
File Type: jpg 036c8ee2-1c01-102f-bffb-bccabd56764er.jpg (64.6 KB, 441 views)
Old 01-10-2013, 04:36 PM   #136
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
I wonder if this was for the 07 sedan as well
Originally Posted by sw07gt
Old 01-10-2013, 05:37 PM   #137
Yes - It is for Sedan's as well.
Old 01-10-2013, 10:07 PM   #138
CoryM
Drives: 2009 5-door, 5-speed
Was working on a 2012 SE today and it looks like they still haven't corrected the problem. Loosened both bolts with my impact gun (doing alignment) and both sprayed rusty water at me. Not good. I think the best fix for most of us would be drilling a small hole to drain the water, rather than trying to prevent water from getting in. I need to align my car soon, so will try to figure something out and take pictures while it is apart.
Old 01-10-2013, 11:59 PM   #139
JumpmanYaris
USAF_SrA_E-4
That will weaken the bolt
Old 01-11-2013, 12:11 AM   #140
CoryM
Drill the subframe, not the bolt
Old 01-11-2013, 10:51 AM   #141
Hershey
Yesterday , brought the T.S.B. to service center and they said they look fine . Also denied to fix a waterpump ( different post ) .
Old 01-12-2013, 10:27 AM   #142
FrankM
what will happen if it brakes when i am driveing the car at 65 on the high way , do i die ? do you lose control of the car ?
Old 01-12-2013, 10:29 AM   #143
FrankM
can you post a picture of where to drill the hole , THanks That would be a big help .
Old 01-12-2013, 10:32 AM   #144
Hershey
Wish they would just replace the bolts .
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
