Old 06-05-2012, 12:47 AM   #19
JohnnyMalice
Drives: 2007 Toyota Yaris 4 door sedan
Would It benefit a Automatic in anyway?
JohnnyMalice is offline   Reply With Quote
Old 06-05-2012, 10:00 AM   #20
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Yes, it has nothing to do with the transmission, but the signals from the throttle to the ecm. It can help all cars with drive by computer.
Colin Chapman disciple
Old 06-06-2012, 11:29 PM   #21
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I thought about doing this too. E-throttles main purpose is for emissions. It eliminates sudden rich conditions that the converter cant clean up. Thats why the down rev is slow and tip in is gradual to make sure what fuel thats being injected is completely being used, resulting in reduced emissions.
I wonder if one could swap xb/xa throttle along with matching ecu could work...?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-07-2012, 06:25 AM   #22
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I guess that would just depend on what else is managed by the ECU. It would be worthwhile to at least look at the EWD and find out what connections go into/out of the ECU.
Old 06-07-2012, 09:34 AM   #23
Different pinouts on the xA and xB. You'd then also have to (1) make a custom harness or (2) hardwire the new ECU into place.
Old 01-24-2013, 12:31 AM   #24
Crazy Butcher
Drives: Yaris 2008
Okay guys, Bringing this thread back from the dead, Talked about going the cable throttle way well now i need answers, I was thinking about using a set of 2004-2005 pedals since they were by cable, then i wouldve used the echo's throttle but i was told it may be too small so i got suggested a Celica throttle.i was told that any throttle mod needed to be managed with an standalone unit since the stock ECU wouldnt do it. So know the question is,
How does the standalone works?for the wiring how's it done? do you keep the stock plus the standalone or does the Standalone does it all by herself?
I hope you guys can help me out with this.
Crazy Butcher is offline   Reply With Quote
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
xB Ported Throttle Body & 1zz cable driven TB H3LlIoN Items for Sale by private party 10 03-06-2011 10:26 PM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 05:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
