#19 | |
play every day
#20 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
#21 |
Can anyone pls guide me as to which "colder" spark plugs do i need?
May be someone knows the part number? Thanks |
#22 |
Form>Function
#23 |
Blitz says to run plugs that are one step cooler than the stock (NGK BKR5EIX is equivalent to stock), suck as the NGK BKR6EIX. I run NGK BKR7EIX, which are two steps cooler.
#24 |
Form>Function
Noob question but what exactly are colder plugs for and why only for F/I? Because of the extra heat generated by the increase in explosions? And what would be the reason going one step vs two steps colder or vice versa?
#25 | |
http://www.ngksparkplugs.com/tech_su...k_plugs/p2.asp
#26 |
Form>Function
Very nice thanks ^^^ makes sense
#27 |
2ZR swap. DO IT! Ask how!
Damn, more things for the S/C shopping basket. Good to know up front, though!
#28 | |
^ I already stopped even worrying for anything less than 50 bucks )) (new belt, spark plugs, hoses/silicone couplings, new bearing for a pulley plus installation (do not have a press) - decided to change it as well, etc.) ))))))) |
#29 |
#30 |
Would not dare drilling it - looking too good )) Just used the Y-splitter for one of the existing vacuum tubes.
#31 |
Question re AFR pls and further steps
Before SC the car would pretty much always run at around 14.4- 14.5 AFR, exception being only prolonged accellerations up the hill (I live in Canada) during which occasions AFR would "drop" to may be 12-13. After SC - SC NOT ENGAGED: prettu much the same as before - SC ENGAGED: durring acceleration under 3-4k RPM - AFR between 14 and 14.5; during "pedel to the metal" type accellerations at RPMs above 3-4 k, the AFR would drop to some value between 11 ans 13. I bought NGK6 colder spark plugs and will install them today. Question: what else do I need to do, pls? Thanks for opinions P. |
#32 |
Ps: my AFR sensor is installed between the first and second cats - I know - not the best way of doing this but still. Kind suspect it would be sort of biased towards lean readings.
#33 |
^ That's where the second O2 sensor goes -- where is that sensor? Or do you have two bungs in a row now?
#34 |
I have a second bung welded near the second OEM sensor. Not one after another though
| Factory OEM Scion T1814 Pioneer Deck in the Yaris PICS | auxmike | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 08-02-2012 11:30 PM |
| Putting scion seats in a yaris | xnamerxx | Cosmetic Modifications (Exterior/Interior) | 3 | 03-09-2010 12:17 AM |
