Old 04-10-2013, 02:12 PM   #73
^ At $800 each (x2 !), they are pricey. Easier and cheaper to regrind camshafts here. We're doing a set for a customer now.
Old 04-10-2013, 02:26 PM   #74
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
REALLY? You guys do regrinds? Didn't see that service available online. If we were looking at the JUN cam profile, Duration (mm): 66 (264) Lift (mm): 9.5 (race profile) OR Duration (mm): 63 (252) Lift (mm): 9.0 (street profile), what could something like this run? Rough estimate?
Originally Posted by fast2882 View Post
for racing camshaft, Jun auto already release a higher lift and timing camshaft, in indonesia, we use these cam when we race.
+$1000 for cams seems REALLYdiculous for our lil 1.5...
JustDidIt is offline   Reply With Quote
Old 04-10-2013, 03:25 PM   #75
Jason@SportsCar
$800 x 2? I paid 84,200 Yen for the 9.5 cam set and 14,000 Yen for air shipping, at that time the total was $1077.23 to my door. With the current exchange rate (assuming the price is still the same) $984.95.
Now the hidden cost is that you may need to relieve the head to fit the 9.5mm cams, the taller lobes can hit the head casting.
We have used a regrind before, works fine, and other than shimming the lifters you don't need to touch the head.
Old 04-10-2013, 03:55 PM   #76
^ That's right the price did come down. I still say it's pricey compared to sending off a couple of cores for grinding, especially if the head doesn't need corresponding work.
Old 04-10-2013, 04:03 PM   #77
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
What about just getting MI to make a Head with +1 mm valves, a set of custom ground cams, and a port and polish? then it should be as simple as making sure the cams are clocked right, the head is torqued down to spec and the timing marks line up, then go go go.
^ just saying, if we ask enough they eventually will have to supply to the demand.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 04-10-2013, 04:17 PM   #78
JustDidIt
JustDidIt's Avatar
^ That!!
Old 04-10-2013, 06:51 PM   #79
nanoss
Drives: Toyota yaris sedan
Ok a friend was telling me that the scion xb 1st gen the exhaust camshaft have more duration the same valve lift but longer the time to close the valve. I am interested in jun cams but the thing that is keep me worried is the lift since the piston are a lill bit higher the valve could hit the pistons...
nanoss is offline   Reply With Quote
Old 04-11-2013, 09:47 AM   #80
Viperoni
Drives: 2005 Toyota Echo
Thanks for posting again Nanoss!
Does anyone have specs on the cams?
I did a quick search and couldn't find a FSM.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 04-11-2013, 02:28 PM   #81
nanoss
Yeah that will be usefull to know...
Old 11-04-2014, 03:32 PM   #82
salmanghiyas
Fugitive
Drives: 2007 Yaris 4 Door Hatch
Thread dead ?
salmanghiyas is offline   Reply With Quote
Old 11-07-2014, 12:23 AM   #83
japle
japle's Avatar
Drives: Vitz S 2007 LB
any updates?
japle is offline   Reply With Quote
Old 11-22-2014, 04:03 PM   #84
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Lotta work for very little HP. Me, I am shootin fer handling first, then play with braking. But, even the Blitz sounds better, and that too is a lotta dough for a little go
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
Old 12-31-2014, 10:30 AM   #85
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I've been running the Prius pistons for a while now, cero problems ��
Next step is getting a emanage and tune it with something other than 93 octane for Track Days only ��
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 01-11-2015, 10:08 AM   #86
Flipper_1938
Flipper_1938's Avatar
In your opinion, how much hp did you gain with the piston swap?
Old 01-11-2015, 02:52 PM   #87
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Prius Pistons + port & polish head where 18whp, and its a fact not an opinion cause the car was dynoed before an after (Y)
Old 01-22-2015, 11:24 PM   #88
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
YarisPR who did your port and polish?
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-24-2015, 11:36 AM   #89
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
Angelo still lives lol
monchito18 is offline   Reply With Quote
Old 01-28-2015, 10:49 PM   #90
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Lets meet up in Puerto Rico... lets do that soon...
R-CaT
Project Yar 2ZR
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 09:38 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 02:44 PM
SEDAN LOVE CHILD OF CAMRY& PRIUS jay cobbs Fuel Economy Forum 0 05-23-2012 01:42 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 11:30 AM
