Drives: yaris yrs 2007 Join Date: Sep 2012
metallic noise when accelerating
Hi all,
I've got a 2007 Yaris 1.5 5dr automatic hatch (105,000km on odometer) and i've got some weird noise when i'm accelerating. Sounds like ball bearings rattling in a can, or some bearing noise. It's very inconsistent, some days it's really loud and some days it's very faint. - The noise happens when going up hills, around 1500-1700rpm when accelerating - Seems to only sound when there's a certain load on the engine, if i accelerate very slowly there's no noise - noise happens at any speed, accelerate from standstill, and crusing at 50km/h then accelerating hard etc. - coasting (any speed) or braking and the noise doesnt exist - revving the engine in neutral there's no noise - checked alt/ac belt, it's in good condition and tension is good, also checked the pulleys, no major sounds/play when rotating without the belt. anyone have any ideas? Thought it was pinging and tried a higher octane fuel (no difference). Seems to be related when the engine moves when accelerating???? Been looking on previous posts, could it be the exhaust donut gasket between the manifold and front pipe? |
![]() ![]() Drives: Yaris 1F8 Join Date: May 2013
Heat shield, vacuum leak @ throttle body... im pretty sure its nothing serious..
Check for vacuum leaks.. |
![]() ![]() Drives: Yaris Join Date: Feb 2013
Hi poida . Here is my post http://www.yarisworld.com/forums/showthread.php?t=54069
Did you sort out your problem?. |
Heat shield over catalytic converter
| Compilation of Yaris TSBs | eTiMaGo | DIY / Maintenance / Service | 72 | 07-04-2024 11:36 AM |
| Whirring Noise when accelerating | RatedRVD | DIY / Maintenance / Service | 11 | 06-06-2012 01:07 PM |
| drivetrain is making funny noise while accelerating | whoknows89 | DIY / Maintenance / Service | 0 | 02-09-2012 05:28 PM |
| Help With Reverse Noise???? | JoshW | DIY / Maintenance / Service | 0 | 09-09-2011 01:27 PM |
| Strange Noise when accelerating! | cybertees | DIY / Maintenance / Service | 22 | 05-24-2009 09:37 PM |
