#19 |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
I got mine one (not installed yet), because I just don't see how much space is left around the bumper, and jumping out several times while parking is a pain in the a§§ ;)
#20 |
Ya know, I haven't paid attention to that part. I might be able to figure out how to measure it, though...
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#21 | |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
However, not to knock throttle controllers, my NTD one developed "Limp mode" issues, and throwing CEL for like throttle position voltage too low or something along those lines, meaning the car, just says, "throttle is giving weird signals, better just disregard what its tell the engine to do" Least limp is much safer than uncontrolled acceleration.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#22 |
You should check that the power cables aren't shorting out on you. I had to resolder mine a few weeks ago. Hopefully that will fix your issue.
#23 |
Does that mean open up the control box? Ill take a look at all solder points when i put it back in the car tomorrow.
#24 |
Nope, I'm talking about the power cables that get connected to the OBD port. I was getting limp mode every time I pressed the clutch pedal and it turned out that the power cable got tangled up a bit.
#25 | |
#26 |
That explains the clicking sounds (same sound the box makes when changing modes) when I gently tug on the cables. Thank for the tech tip
#27 |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
Just mat it when the light turns green
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
| Tags |
| body, cable, electronic, thottle |
| 1.8L throttle body dimensions drawing | CrankyOldMan | DIY / Maintenance / Service | 5 | 03-09-2016 09:30 PM |
| Cable throttle body | Crazy Butcher | Performance Modifications | 23 | 01-24-2013 12:31 AM |
| Throttle Body spacer? | jekqmb | Performance Modifications | 2 | 10-04-2011 11:02 PM |
