Old 04-15-2014, 06:28 PM   #19
ddeschen
ddeschen's Avatar
Drives: 08 4dr Hatchback
10 days after.... Still happy with the springs and no rubbing so far. One thing I noticed is the significant improvement of straight line stability in strong winds. This is achieved by the TRD springs combined with the 205/50/16 tires. Major difference with this combination.
ddeschen is offline   Reply With Quote
Old 04-15-2014, 11:57 PM   #20
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
I noticed that too after lowering springs. Doesn't jump around as much with hydroplanning also!
trunkout is offline   Reply With Quote
Old 04-18-2014, 08:49 PM   #21
MUSKOKA800
MUSKOKA800's Avatar
crazy site will not let me post pic's. Best you can do is check the pic under my user name.
Old 04-19-2014, 02:49 PM   #22
WRX
Drives: 2012 YarisLE 2014Lexusct200hF
I have TRD springs for almost a year now, with TRD shocks, cut bump stops in front in half. Wheels Konig Feathers 15x6.5. Tires are 185/60R15 Continental ProContact with EcoPlus Technology. I'm at 30.5 psi in fronts and 31.5 psi in rears. I like this set up cause I can go over speed bumps and I have enough cushion where, when I go over rough pavement my dash doesn't rattle. Handling is good I can still drive like I am in my upgraded WRX, yet have great gas mileage, and taller tire means I can have more people in car and still clear speed bumps which I am surrounded by.
WRX is offline   Reply With Quote
Old 05-14-2014, 10:52 PM   #23
gojon17
Drives: Yaris Sedan 2011
Anyways this is mine with trd springs and 17 inch rims
[IMG][/IMG]
gojon17 is offline   Reply With Quote
Old 05-16-2014, 07:32 AM   #24
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
That is a nice looking car!
Old 05-16-2014, 08:53 AM   #25
gojon17
Thanks buddy!!
Old 05-16-2014, 09:15 AM   #26
IllusionX
Drives: 07 Yaris Sedan Aero
205/55R15 is not going to make your car lower than your stock 185/60R15. just FYI..
Old 05-16-2014, 10:08 AM   #27
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
I had them! really nice springs, really stiff.
monchito18 is offline   Reply With Quote
Old 05-16-2014, 03:10 PM   #28
gojon17
yeah they are.. my only mistake about this was cutting bumstops too much... fricking rubbing is awful
Old 05-17-2014, 09:53 AM   #29
monchito18
monchito18's Avatar
Drives: Yaris sedan
Did the same with 2" lowering springs and it rubs everywhere!
here is a picture when I had TRD
Old 05-17-2014, 05:14 PM   #30
gojon17
Yeah i still have the chunks i cut off the bumstops.. im gonna glue some the leftover bumstops... seriously.. i rather being a bit harder but i want my car to stop bouncing before i get to the rubbing part
Old 05-17-2014, 07:08 PM   #31
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
ok ...bumpstops are just that they are there to stop ur strut from bottoming out saving them from damage ...by having them longer will stop rubbing but all that ur doing is riding on them as for bounce that is do to worn out struts/shocks a proper set up will have no bounce and bumpstops will only come in to play if u hit something , like a pothole in the road.
Old 05-17-2014, 09:10 PM   #32
gojon17
My shocks are fine... it only rubs when i go on deeps on highway.. but theres some on my way to work and i hate that.. i cut like 3/4 of bumstop... what im gonna do is put 1/4 more so its like i just cut half.
Its not like im bouncing everywhere... But when road gets bad i rub and hate that... Either fix that or work on fenders... I do all the stuff on the bodyshop i work at... so me very lucky i have plenty of tools... i also trimmed my front springs just a bit so it lowers it a bit more in front.. thats why it rubs even more
Old 05-17-2014, 09:16 PM   #33
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
think what u need is stiffer springs one can only go so low with out going to coilover setup ...or body work.
Old 05-18-2014, 06:24 PM   #34
monchito18
monchito18's Avatar
Drives: Yaris sedan
or stiffer struts
Old 05-18-2014, 07:35 PM   #35
MUSKOKA800
MUSKOKA800's Avatar
no bump stop cutting recommended for TRD springs. I have FatCat bump stops installed and while some rubbing occurs no bottoming has been experienced in 5 years now. TRD dampers surely help prevent that much motion.
Old 05-18-2014, 11:49 PM   #36
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
true on TRD springs front only .5 lower over stock...anything lower and do cut.
Tanabe NF210 + Tokico vs. TRD springs and shocks fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-19-2009 03:42 PM
Anyone install only trd springs and rear sway? AdeJong 03 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 08-13-2009 05:35 PM
TRD 18" RIMS & SPRINGS rossman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 07-27-2009 12:41 AM
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 10:02 PM
TRD lowering springs or Tanabe NF210? matthewboii Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 03-18-2009 02:42 PM
