Old 03-29-2014, 12:38 AM   #1
gojon17
Drives: Yaris Sedan 2011
Do you have TRD springs? Did they settle?? Pics??
Just curious!! thanks guys!!
gojon17 is offline   Reply With Quote
Old 04-02-2014, 02:14 PM   #2
gojon17
bump
Old 04-02-2014, 04:58 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Expect 5% u got good quality springs should be much I would recommend an alignment for toe after they some time of driving
Old 04-04-2014, 06:54 PM   #4
ddeschen
ddeschen's Avatar
Drives: 08 4dr Hatchback
Just got the TRDs installed today and some odd numbers for height before and after. Left rear reads 1.625" lower. But roughly, 1" lower front and 1.25" right rear which is OK for me. I will give some time to settle and will post final numbers and pics. By this time I'll check if something wrong with the LR...
ddeschen is offline   Reply With Quote
Old 04-04-2014, 07:28 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Was that with a full tank of gas I find my car sits off with less gas but over all even, not on TRD tho
Old 04-04-2014, 07:55 PM   #6
gojon17
Thats awesome... In cutting a little bit of my front ones. (Its safe) to lower a bit more
Old 04-05-2014, 02:49 PM   #7
ddeschen
ddeschen's Avatar
Before and after readings were taken with the same quantity of gas, about half tank.
Old 04-05-2014, 04:26 PM   #8
Make sure the rear springs are both sitting correctly in their perches, which have depressions to hold them. And that you re-used your stock top hats.
Old 04-06-2014, 07:07 AM   #9
gojon17
thats kind of weird... mine went down about 1.5 inches all around... Red trds
Old 04-06-2014, 08:25 AM   #10
ddeschen
ddeschen's Avatar
Measures taken from ground to top/center of wheel well. 2 sets of measures were taken with the car moved in between. The final number represent the average.
BEFORE
FL: 25 7/16” FR: 25 1/2”
RL: 25 3/4” RR: 25 13/16”
AFTER
FL: 24 7/16” FR: 24 3/8”
RL: 24 3/16” RR: 24 5/8”
Old 04-06-2014, 08:30 AM   #11
ddeschen
ddeschen's Avatar
The job was make at a shop with an experienced mechanic. I trust their capabilities and could not imagine they did something wrong. At least, winter is almost over here and Ill switch to summer wheels/tires next week and will take this opportunity to have a check while the car is jacked.
Old 04-06-2014, 09:03 PM   #12
ddeschen
ddeschen's Avatar
Final result; the fit is perfect with the 205/50/16. Exactly what I wanted.
Old 04-06-2014, 09:26 PM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Looks good ....no rub ?
Old 04-06-2014, 10:10 PM   #14
ddeschen
ddeschen's Avatar
No rub so far. Only few kms done but will keep you posted.
Dan
Old 04-06-2014, 10:15 PM   #15
Rigaud
Drives: 2009 Yaris
Nice set up! ;)
Just noticed your near Montreal.........I'm in Rigaud.
Rigaud is offline   Reply With Quote
Old 04-07-2014, 01:51 AM   #16
gojon17
Wow looks good!! perfect gap i would say!!
Old 04-07-2014, 05:14 PM   #17
MUSKOKA800
MUSKOKA800's Avatar
Over the first year mine settled at least one inch past the 1.5" specified. Looks rather slammed now. Stock Yari look like 4X4"s in comparison.
Old 04-07-2014, 07:23 PM   #18
gojon17
Man would mind posting pics?? some of the wheel gap as well??? :)
Tanabe NF210 + Tokico vs. TRD springs and shocks fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-19-2009 03:42 PM
Anyone install only trd springs and rear sway? AdeJong 03 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 08-13-2009 05:35 PM
TRD 18" RIMS & SPRINGS rossman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 07-27-2009 12:41 AM
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 10:02 PM
TRD lowering springs or Tanabe NF210? matthewboii Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 03-18-2009 02:42 PM
