![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
ECU Help
Hey guys,
I recently completed a Manual Conversion on my Vitz (JDM 2NZ-FE) however I ran into one problem. The donor car I did the swap with didn't have a VVTi controller so we were forced to keep my Automatic Harness and ECU; because of this my Engine Check light is constantly on. My question is, Would I be able to use a 2004-2006 MT XB ECU to fix my problem even though they came with 1NZ engines instead of 2NZ engines? I think it's the closest vehicle to mine since XBs are non OBDII as well. Thanks -Justin
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
i'm sure you will have to find a 2nz ECU..
#3 | |
Basically, the 1NZ ECU from the XB won't work?
No. It would need to be from another 2NZ vehicle, if you swapped the tranny, but kept your same 2NZ engine. All 1NZs are single cam, and their ECMs lack the input for the 2nd cam sensor and output to drive the 2nd oil control valve.
Wow, thanks for the info. I thought they were they same engine just a different stroke. Where can I read up more about these engines?
#7 | |
So, back to your original question - Your fuel maps would be a bit rich with a 1NZ ECM, but other than that it should be OK. Can you post a picture of the ECM connectors on your Vitz ECM?
I was just about to post up about that haha
Sent from my iPod Touch |
#9 | |
Running rich won't be bad as long as I can get rid of the check engine light. I ordered a bigger throttle body, hopefully it fits. Next up are bigger injectors and an adjustable fuel pressure regulator. I plan to dabble in a bit of forced induction soon. I'll see if I can get that pic for you in the morning. Thanks -Justin
| Tags |
| ecu, manual, swap |
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| standalone and stock ecu | Radou | Performance Modifications | 0 | 06-16-2013 04:47 PM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
