Old 05-01-2014, 06:17 PM   #5
Originally Posted by Ryze268 View Post
Basically, the 1NZ ECU from the XB won't work?
No. It would need to be from another 2NZ vehicle, if you swapped the tranny, but kept your same 2NZ engine. All 1NZs are single cam, and their ECMs lack the input for the 2nd cam sensor and output to drive the 2nd oil control valve.
Tags
ecu, manual, swap
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 04:47 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
