Old 05-01-2014, 03:01 PM   #1
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
ECU Help
Hey guys,
I recently completed a Manual Conversion on my Vitz (JDM 2NZ-FE) however I ran into one problem.
The donor car I did the swap with didn't have a VVTi controller so we were forced to keep my Automatic Harness and ECU; because of this my Engine Check light is constantly on.
My question is, Would I be able to use a 2004-2006 MT XB ECU to fix my problem even though they came with 1NZ engines instead of 2NZ engines?
I think it's the closest vehicle to mine since XBs are non OBDII as well.
Thanks
-Justin
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
ecu, manual, swap
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 04:47 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
