Problems with My RS - lights problems
Hi All,
Recently i have a strange problem with my Vitz, sometimes when i try to switch on the side lamps/fog lamps and rear fog lamps or either or it simply nothing happens... Not even the interior dashboard light's on indicator/clusters switch on.. If i try multiple times than it works ![]() Also i have noticed that occasionally when i open my car using my key remote it locks its self automatically after few seconds ![]() Does anyone have ever had this issue? Thank you, Gianni |
Further to the above post, the bright and hid works perfectly even when the side lamps, rear break lights etc do not work...
Do the brake lights work when the fog light switch is not on?
Or, rather than the brake lights, do you mean that the tail lights do not light up when the issue is occurring?
Thank you for your reply.
Yes the tail lights do not work as well when this occurs, i switch on the side-lamps etc and nothing works apart my bright and HID... Thank you |
Any suggestions?
I think the switch internals of the fog light switch are failing.
| BACK UP LIGHTS PROBLEMS | jaimico | DIY / Maintenance / Service | 11 | 01-28-2017 12:24 PM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| Rear break/STOP lights, tail lights are out, plate lights working? | MzTyla | DIY / Maintenance / Service | 2 | 06-20-2013 07:56 PM |
| LED tail lights installed | Cutie Pie #2 | Cosmetic Modifications (Exterior/Interior) | 10 | 08-20-2012 11:25 PM |
| Fog lights, or parking lights stopped working | sylvermagyk | DIY / Maintenance / Service | 4 | 03-24-2011 05:13 PM |
