![]() Drives: Yaris '99 1.0 vvti Join Date: Aug 2014
Stuck oil drain plug..Yaris '99
Hi, bit of a problem...just running through a small service on my yaris, and get to changing oil...filter etc and the drain plug for the oil is stuck propa good, any advice/tricks to free this nut up?
Cheers everyone.. Kev |
That's a tough one. You really don't want to shear off the bolt. I would try a piece of pipe over a wrench, for extra torque. Considering what's above it, it really shouldn't be stuck due to rust, so it was likely just over-torqued on the last oil change.
I once had hard time to undo the bolt on a corolla. It was way over torqued by the previous person who maintained it.
#4 | |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
![]() ![]() Good luck! |
Pheeew, A little perseverance and car jacked up so I could access a bit better and I managed to get this bolt off..oil change now done!
Now on to replacing the headlight cover..any help gratefully received.... Thanks for all advice everyone.. Kev |
All you can do is apply enough force to remove the bolt. It it comes out in one piece...great! If the threads strip the oil pan is easily replaced.
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
This was posted in the wrong section, moved it. Please remember to post your threads in the correct section.
2ZR swap. DO IT! Ask how!
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-13-2014 11:17 PM |
| Oil Analysis Results 2011 Yaris | Nu18F | DIY / Maintenance / Service | 3 | 10-31-2011 10:55 PM |
| Oil drain plug gasket question | schleppy | DIY / Maintenance / Service | 7 | 04-17-2009 05:35 AM |
