Old 08-20-2014, 04:04 PM   #1
Blueneaker
Drives: Yaris '99 1.0 vvti
Stuck oil drain plug..Yaris '99
Hi, bit of a problem...just running through a small service on my yaris, and get to changing oil...filter etc and the drain plug for the oil is stuck propa good, any advice/tricks to free this nut up?
Cheers everyone..
Kev
Blueneaker is offline   Reply With Quote
Old 08-20-2014, 07:03 PM   #2
That's a tough one. You really don't want to shear off the bolt. I would try a piece of pipe over a wrench, for extra torque. Considering what's above it, it really shouldn't be stuck due to rust, so it was likely just over-torqued on the last oil change.
Old 08-20-2014, 07:05 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
I once had hard time to undo the bolt on a corolla. It was way over torqued by the previous person who maintained it.
Old 08-20-2014, 07:07 PM   #4
Yaristeve
Drives: 3-door hatch
Or... cross-threaded
Good luck!
Old 08-21-2014, 12:57 PM   #5
Blueneaker
Pheeew, A little perseverance and car jacked up so I could access a bit better and I managed to get this bolt off..oil change now done!
Now on to replacing the headlight cover..any help gratefully received....
Thanks for all advice everyone..
Kev
Old 08-21-2014, 02:16 PM   #6
bronsin
bronsin's Avatar
All you can do is apply enough force to remove the bolt. It it comes out in one piece...great! If the threads strip the oil pan is easily replaced.
Old 12-23-2014, 05:07 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
This was posted in the wrong section, moved it. Please remember to post your threads in the correct section.
Old 12-23-2014, 07:40 PM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
What the hell? Spammers in the wrong thread?
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Oil Analysis Results 2011 Yaris Nu18F DIY / Maintenance / Service 3 10-31-2011 10:55 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
