Old 12-26-2015, 03:52 AM   #91
tankm249
Drives: Toyota Yaris S 2011
Part number
I know the post is old but I would like to know the prius piston part number. Some stupid online sellers think the 1nzfe pistons and 1nzfxe pistons are the same. There are a lot of racers doing this mod in PR. But I wanna make sure I purchase the right piston. I don't wanna end up with the same piston I have. Please help.
tankm249 is offline   Reply With Quote
Old 12-26-2015, 10:51 AM   #92
Rigaud
Drives: 2009 Yaris
Go on RockAsuto, you'll find the right part. \Their usually around $65 USD each.Also, might not be in stock at Rock Auto. Maybe some else here will suggest another place that has them stock
Go back a few pages and read..........part numbers are posted.
Old 01-31-2016, 09:21 AM   #93
tankm249
Thanks
Old 01-31-2016, 02:48 PM   #94
tmontague
tmontague's Avatar
Can these pistons be run safely without an engine management on 94octane gas?
Obviously you wouldn't maximize the potential unless you had at least a piggyback ecu but i'm curious if the stock ecu can handle the increased compression if you run the appropriate octane gas?
Old 01-31-2016, 04:22 PM   #95
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Don't waste your time if you're running stock cams, the static compression ratio is so high that you'll be fighting detonation at low rpms. For these cams to really work you'll need some pretty aggressive cams.
2014 BSpec Divisional Champion
Old 04-05-2017, 03:44 PM   #96
hmmm
Old 04-05-2017, 10:50 PM   #97
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I'am rnning the prius pistons, with 93oct and greddy emanage ultimate
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 04-06-2017, 03:29 PM   #98
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
I'm already running 1NZFXE pistons on 93oct ... but haven't updated my cams to 1NZFE yet.
JustDidIt is offline   Reply With Quote
Old 04-06-2017, 11:05 PM   #99
Rigaud
Drives: 2009 Yaris
Old 05-24-2017, 12:30 AM   #100
Yarisblu
Drives: Blue hatchback 2 door 2008 yar
Do you know if those pistons would work on a 2nz-fe?
Thankss
Yarisblu is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 09:38 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 02:44 PM
SEDAN LOVE CHILD OF CAMRY& PRIUS jay cobbs Fuel Economy Forum 0 05-23-2012 01:42 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 11:30 AM
