#19 |
![]() Drives: altima, yaris Join Date: Jul 2009
just put an amp in my gf's yaris and i used a nipple located on the passenger side of the car. If you pull off some of the carpet underneath the glove box you'll see it. You can easily feed the cable through and then just zip tie it to diff parts under the hood so it doesn't get tangled up in anything and looks clean.
#20 |
Thats what I did. I ran a 8 guage the first time, then came back later and ran a 4 through the same grommet. It fit like a dream.
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
#21 | |
![]() ![]() Drives: 07SedanS06Taco Join Date: Oct 2008
Firewall
This is the bushing I used, Thanks CTScott, worked perfect. ![]() I used a fiberglass rodder and pushed it through slowly on the outer portion of the bushing, tied on the power cable, wiped some car wash soap on it and it slid right in. Last edited by othater; 10-22-2011 at 08:35 PM. Reason: edit old post |
#22 | |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
(another solution) I had similar problem some time ago and used @the hole@ proposed by 3cylTurbo (who recently posted his HB audio install here) - hole right above the ECU (square electronic block) on the passenger side - which also worked in my case I ran my wire to the amp under the passenger seat (in which case the hole on the passenger side worked out very well) |
#23 |
Thanks for the idea, but the loose underprotected live wire does not look good ((
#24 | |
![]() Drives: 2009 Toyota Yaris; 4 dr Sedan Join Date: May 2014
Finally, I'm through the firewall on the passenger side; I used the grommet hole designed by Toyota just above the ECU. I'll add detailed instructions on how I finally got through & include annotated photos this weekend. I had to go to a junk yard & look at wrecked Yaris that had the engine & ECU already removed. When I saw the grommet/hole in the firewall I then knew what to look for from the engine compartment & from the passenger side under the glove box. Last edited by lasermn; 12-25-2015 at 12:41 AM. |
#25 |
Mr. 155 and climbing
If I can I will share a photo or two of mine. Could be the weekend though until I can.
Sent from my XT1575 using Tapatalk
#26 |
Here are a couple pics of the factory grommet holes on the passenger side.
![]() ![]() ![]() Sent from my XT1575 using Tapatalk
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Running Firewall Power Wires for subwoofer | MacMaster761 | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 03-06-2010 03:04 PM |
| Power wire gauge vs stereo wattage | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 02-24-2009 02:16 PM |
| Harman Kardon Drive + Play for IPOD | sroberts | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 07-01-2006 01:05 PM |
