Old 01-05-2016, 08:50 AM   #1
MustiRauf
Drives: 2007 Toyota Vitz 1.0
Steering Swap
Hay guys. So I have a 07 Vitz that comes with the standard plastic'ish steering which I hate driving with.
I found a leather replacement wheel at the junkyard and I thought I could just swap the airbags and be done with. Problem is that the airbag on the stock wheel is held by the 2 Torx screws at the 4-8 o'clock positions. And I noticed that there are no screw holes on the leather wheel.
Also, the inside frames are a little different. Can anyone tell me what type of airbag goes into the leather wheel, or if the leather wheel is even from a vitz/yaris? The size and airbag fit in perfectly so it might be from the saloon version?
The inside of the standard wheel ( reference picture )
The Leather wheel I bought.
MustiRauf is offline   Reply With Quote
Old 01-17-2016, 04:07 AM   #2
MustiRauf
So I tried fitting the wheel onto the car after removing the original wheel and it dose not fit. The center hole is smaller on this wheel than the standard one so if anyone could tell me what car this wheel came off, I can maybe sell it easier by explaining it to the buyer.
Old 01-17-2016, 12:55 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
I replaced my stock plastic steering wheel with a leather one from a Scion. Direct replacement and no more sweaty palms.
Old 01-17-2016, 03:00 PM   #4
Frank the Tank
Drives: 2007 Toyota Yaris
Does the scion steering wheel come out farther than the stock one.
Frank the Tank is offline   Reply With Quote
Old 01-18-2016, 05:11 PM   #5
MUSKOKA800
MUSKOKA800's Avatar
It's dimensions are identical. The spokes are shaped a bit different at the wheel (narrower) so the outer sides of the airbag don't match up the same as the stock wheel but a layman wouldn't notice. The only difference is the leather.
Yaris Steering wheel Swap with Controls. A1phazu1u In Car Entertainment + Electronics (audio / video / alarm) 2 02-27-2013 01:11 PM
steering wheel swap over nickos Cosmetic Modifications (Exterior/Interior) 8 08-04-2011 06:55 AM
Steering wheel swap Maitre_Te_Te Cosmetic Modifications (Exterior/Interior) 2 10-18-2010 12:51 AM
Steering swap blackvvti Cosmetic Modifications (Exterior/Interior) 3 02-04-2009 10:27 AM
