![]() Drives: Yaris 2007 Join Date: Mar 2016
Poor reception and radio harness
Hi,
I just install an aftermarket radio witch is a Dual brand, the only problem is the poor reception, in fact, any local station has a poor signal. However, the antenna connector is connected correctly. Any idea? The factory radio come with three harness, it take only two for the aftermarket radio to make it work. What is the use of the third harness? Thanks. |
Our antenna are powered. Make sure you have wired in the antenna power, not just the big black signal wire. There have been a number of instances over the years where people have not hooked up the power wire. Without it, reception truly does suck.
Yes it must be that, because i connect the two blue lead togheter witch one come from the after market radio and the other to the harness adapter. Everything ok now. I still dont know what is the use of the third harness. Is it possible this is for steering control option?
Thanks. |
Probably.
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| Wires Inside the Yaris & What They Do | The Architect | DIY / Maintenance / Service | 149 | 10-18-2022 03:32 AM |
| 09 radio harness compatibility? | Yodar | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 12-25-2010 12:24 AM |
| radio harness | ryota | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 08-08-2009 07:51 PM |
| Factory wire harness or plastic aftermarket piece for aftermarket radio????? | Yarisguy13 | Great Lakes | 1 | 09-17-2007 10:14 AM |
