#1 |
![]() Drives: 3DHB Yaris 2009 Join Date: Nov 2010
09 radio harness compatibility?
I've been lurking - first post.
Doing a little audio upgrade on the cheap. Anyone know if the radio harness for an 07 is compatible with 09 Yaris? I'm looking on ebay (item # 390256846583 ) but they list the kit as fitting 07 only. Compatible? I'll be installing an Infinity Basslink and want to keep the stock HU. Any suggestions for doing it right? I've read most of the posts and they have been helpful. Thanks! |
Yes - For the Liftback the harness and trim kits are compatible between all years (06-11).
#3 |
Thanks!
Good to know. I will proceed with my plans then. Thanks!
#4 |
update
I ended up going with a Kkenwood bass tube and amp combo and I'm installing it tomorrow. This forum has given me all the wiring diagrams and wire routing info I need. I'll let you know how it goes.
#5 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
i did the same thing as u (tried to keep the stock HU) and i was very happy but now since i changed the hu i noticed a huge improvement.
biggest issues i found were getting the RCA out of the deck, i had to go with a 5 channel amp with a high\low addapter off the rear speaker lines (they have more base line) and a crossover/eq to tune it right. hope it helps
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| radio harness | ryota | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 08-08-2009 07:51 PM |
| Radio Install Harness and Kit | redbluff | In Car Entertainment + Electronics (audio / video / alarm) | 16 | 08-06-2009 02:40 AM |
| Question on 09 Yaris Radio harness | fresnoyaris | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 05-04-2009 06:35 AM |
| Factory wire harness or plastic aftermarket piece for aftermarket radio????? | Yarisguy13 | Great Lakes | 1 | 09-17-2007 10:14 AM |
