#91 |
#92 |
Is there a good/easy way to swap out 5th in an echo for something that'd net lower highway rpms? Will the 0.729 from a c60 fit in a C150 from an echo?
#93 |
I'm not sure on that one. The Echo already has the lowest highway RPM I'm pretty sure with its .815 5th and 3.5FD
You'd have to see if there's any 5 spd gearboxes with the lower 5th. I think the spot where 6th goes is a different Ø |
#94 |
C53 and c59 have .725 5th gears...
#95 |
Chances are pretty good that it'll fit, but you won't know for sure until you're holding them both in your hand.
#96 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
This is an awesome project and I bet it is a blast to drive! But after doing the gear shift drop calculation, you can see the 6600 redline will lead to a LOT of shifting.
#97 |
![]() ![]() Drives: Vitz & Supra Join Date: Jan 2011
Hi Guys,
Im thinking about buying a C160 with Factory LSD from the AE111. My Echi is equipped with the C154, but noted BlueVitz you had the C150?? Also is your dash Digital? Any issues with that? I was looking for a C56 from the Japanese Vitz but they seem harder to find! |
#98 | |
#99 |
![]() Drives: Toyota Echo Join Date: Oct 2016
He has an Echo like yours NCP13 Australian Model
| Tags |
| 6 speed, conversion, gearbox, transmission |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
