Old 09-13-2016, 04:02 PM   #1
Garth g.
Drives: 07 Yaris 2dr hatchback
Cv joint replacement 07 2dr/sway bar end links
I got my sway bar end links today going to replace. I checked the dealership for cv axles they want $400 a side. I don't really want to use ones from Canadian tire or napa they seem to wear out fast. I use my car everyday for pizza delivery so I do a lot of driving. I checked a local wrecker they have Toyota ones with 80,000k on them for $75.00 each, off a 2010 yaris. Should I even bother picking these up?
Garth g. is offline   Reply With Quote
Old 09-13-2016, 09:04 PM   #2
I used one of the aftermarket ones on a Yaris I rebuilt and the quality of it did not seem to be worse than the OEM part. As long as the boots stay flexible over time, they should last just as long.
Old 09-13-2016, 09:52 PM   #3
Garth g.
Thanks for the info. I have surtrack ones on there right now, I checked it again today it's dry? It's not clicking when I turn I might just drive it until it gives. I'm going to change stabilizer links today noticed when I did front pads and rotors that they need to be done. When you bought stuff to rebuild the cv joint what brand did you use? While I'm on here, my airbag light is on would that be the clock spring?
Old 09-14-2016, 04:31 AM   #4
Garth g.
Sorry CT. Scott misunderstood what you were telling me earlier, I think the next time I have to change them I'll try a different after market axle from rock auto. They stock a lot of stuff way cheaper than the stores in Canada and a lot of times it's the same brands. Saved a good chunk of cash so far going with them.
Old 09-14-2016, 05:13 AM   #5
For the CVs, I bought the full Axle assembly, with the CV's and boots all together.
For the SRS issue, it is likely the clockspring, but you can use this procedure to read the code to be sure:
http://www.yarisworld.com/forums/sho...d=1#post557473
Old 09-08-2021, 01:00 PM   #6
crumbs
Drives: 2009 1.5 Hatchback Manual
For the CVs, I bought the full Axle assembly...
Hey do you know what brand aftermarket cv axle you bought? I was looking at GSP NCV69452 & NCV69451 from Rock Auto.
crumbs is offline   Reply With Quote
adjustable sway bar end links group buy!!! turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 51 06-13-2012 11:49 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
C-Pillar Bar Installation Guide AlainMikli Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 05-08-2009 09:29 AM
Review: Adjustable Sway Bar End Links m911gt Performance Modifications 9 04-29-2009 09:25 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
