#19 |
I'm thinking if ANY of the bolts aren't reusable They didn't use the right grade of metal in them in the first place.
That would also suggest the first use of the bolts might result in failure.
#20 |
That I've heard of.
I can't explain it but that would only MAKE ME REUSE THEM!
#21 | |
![]() Drives: 2007 Yaris Sedan Join Date: Oct 2016
"(b) Clean the 6 bolts and their holes." So it appears you really can re-use them which is why the dealers don't stock them. That said, I did end up getting 6 new ones this morning and used those. They came with thread lock on them already. If the shop manual didn't intend for you to re-use them they woudn't tell you to clean them and apply red thread lock which it does. That said, there length difference was 29.29 (new) vs 29.80 (old) which is a pretty big difference. |
#22 |
![]() Drives: 2009 1.5 Hatchback Manual Join Date: Sep 2021
Hello are the flywheel bolts spline or 12 point bolts? Thank you
#23 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2023
Sorry to revive a multi-year old thread but I just completed an engine swap on an '07 Yaris Sedan A/T and am finding all kinds of conflicting info on these flywheel torque specs. Below is the supposed Toyota FSRM and it states the "6 torque converter set bolts" should be torqued to 20ft/lbf (page 176 of the "U340E Automatic Transaxle" chapter). It mentions nothing about torque, wait XX minutes and retorque. Nothing about using Loctite. Nothing about torque then additional XX degrees of rotation. Nothing about replacing the 6 bolts. Can anyone shed any additional light on this?
https://jdmfsm.info/Auto/Japan/Toyot...air%20Manuals/ Last edited by shane21; 02-21-2023 at 01:09 PM. |
#24 |
![]() ![]() Drives: 2009 yaris Join Date: Feb 2016
I'd use fixodent....and forget it!
LOL... I'd use loctite and overtorque a bit and never worry about it again. My oldschool mechanic always said torque specs are bs ... I don't think they are all the time, but for torque converter I'd go tighter. You don't want them to loosen like they did on Dodge caravans over 20 years ago and rattle grind against the bell housing. |
| Questions for new flywheel and clutch | mrbond | Performance Modifications | 11 | 07-11-2013 07:17 AM |
| Flywheel question-1nz conversion-2003 Model | Echo56 | DIY / Maintenance / Service | 0 | 05-21-2013 10:42 PM |
