![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Front rattle mechanic says all is good.
The only thing he mentioned is the front sway bar.He said there is something under the frame that could be worn out?
I have read the thread about the LCA bolts and mentioned that to the mechanic and he aid they were fine.The car rattle both sides going over bumps,not smooth bumps though,more like washboard kinda stuff. |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
open the drivers door and push sideways on the roof hard as if you are trying to roll the vehicle over. It should clunk or click everytime the vehicle rocks side to side. If you have someone else do it, you can look/reach under the car and look/feel for play in the links, or bushings.
#3 | |
I will be getting second opinion but was just hoping some common issue that is yaris specific would be causing noise.Something that a mechanic could possibly look over. I will be checking the end links again just to be sure but cant see both of them going bad after one year.The thing is the noise is not specific to one side of the car. |
![]() Drives: yaris sedan Join Date: Mar 2012
have you solve the problem, my yaris sedan 2007 have a similar rattle noise over small bumps, i have change everything, inner tie rod, outer tie rod, links, swaybar bushing, front strut, top mount bearing of front strut, i have changed twice, firts time cheap brand, second time with good brands like moog, i still have the cheap strut i mount the firts time i dont know if those going bad beacause of the brand they are, still looking for that rattleing noise thats making me crazy
Rattle solved.
It was the front right brakes somehow.Someone said brake pad rattling??
It definitly sounded more then that.Anyhow the front needed brake pads anyway so after changing no more rattle. The caliper guide pins were changed too. Last edited by Pinchlite; 08-25-2018 at 05:25 AM. |
Worn caliper pins caused that on both of my Yaris's. After extensive investigating, checking every conceivable part, I found the calipers were jiggling a tiny bit due to loose pins. Two shops misdiagnosed the issue before I found the problem.
I changed pins while I was at it.I should have mentioned.
Good move replacing the pins.
My top pins were rusted on the top part underneath the boots.I did not notice wear though compared to the new.I replaced boots and sprayed lots of brake cleaner into slider pin tubes and cleaned out with screw driver and rags.Rotors were changed aswell.I was going to do the piston repair kit but decided not to.Brakes feel much better know.
(I think it's amplified through the suspension) For sure because it sounded like something larger,or suspension/steering related. |
brake caliper pins sliders boots rubber bearings
caliper slider pins on my Tercel and Corolla would rust and jam tight...not impressed w/ rubber bearing/boots at each pin end
(never noticed any pin or bearing/boot wear...if anything the bearing/boots swelled w/ lube and age. corrosion blotches on the crome plated pins. hoping this Yaris isn't same parts.) |
#11 | |
Those o rings were easy to put onto pin and insert into caliper.Not sure if I understand?
The rubber boot had nothing to do with O rings. |
I just go sans o ring as it always jammed up when i woukd inspect my sliders which I do every month due to track sessions.
Wire wheel off any rust or replace completely if they at pitted and use a good quality rubber safe high temp grease. Checking the sliders every 6 months is what I found was best as they seems to become contaminated fast on the yaris
#14 |
Yes, it's easy to put the rings on the pin, but I couldn't get the pin to slide in through the new boots once installed them onto the bracket. It's as if the boot lip wouldn't fit fully into the channel in the caliper bracket therefore not creating a completely round hole through which to push the pin.
#15 | |
#16 |
The rubber rings swell and, at a certain point, will not go in. Time to remove or replace them. Can buy boot kits with the rings for fairly cheap. Pins need to move freely, so make sure they stay lubed. Stuck pins will wear your pads out quickly.
FYI, generally worn pins/pads are from driving with rotors with high runout. Caliper/pads slide back and forth rapidly anytime you brake. |
#17 | |
#18 |
The only way I could get the pins to go in was to tap them with a hammer.
Are they proper pins? Mine with new O rings slid in easily. |
| The front brake upgrade thread - just the facts | brushforhire | DIY / Maintenance / Service | 35 | 04-07-2022 07:07 AM |
| Yaris Sedan Deadening and Sound system upgrade | derickveliz2 | In Car Entertainment + Electronics (audio / video / alarm) | 2992 | 11-18-2021 02:14 AM |
| Would these front suspension parts be any good? | Pinchlite | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 02-09-2017 10:07 PM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
| Front bra for S model Sedan? | N9QGS | DIY / Maintenance / Service | 2 | 06-27-2009 08:51 PM |
