Old 08-25-2018, 06:44 PM   #13
CoryM
Drives: 2009 5-door, 5-speed
The rubber rings swell and, at a certain point, will not go in. Time to remove or replace them. Can buy boot kits with the rings for fairly cheap. Pins need to move freely, so make sure they stay lubed. Stuck pins will wear your pads out quickly.
FYI, generally worn pins/pads are from driving with rotors with high runout. Caliper/pads slide back and forth rapidly anytime you brake.
The front brake upgrade thread - just the facts brushforhire DIY / Maintenance / Service 35 04-07-2022 07:07 AM
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Would these front suspension parts be any good? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 02-09-2017 10:07 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Front bra for S model Sedan? N9QGS DIY / Maintenance / Service 2 06-27-2009 08:51 PM
