Old 09-08-2018, 02:12 PM   #1
hmsailor
Drives: 2015 yaris hatchback
DRL to blinkers
has anyone figured out a way to rewire the drls to the signal bulbs? or can i just replace the relay?
hmsailor is offline   Reply With Quote
Old 09-10-2018, 07:05 PM   #2
logoris
Drives: 2017 Yaris SE Blue Streak
Should be no problem just have to find the wires that go to each del and hook them to the turn signals, I do not have a wiring diagram to map it out but it is possible. I was toying with hooking them to the headlights so they get brighter when you turn the lights on and dim when lights off opposite of factory
logoris is offline   Reply With Quote
Old 09-11-2018, 12:26 AM   #3
hmsailor
My DRLs are actually my headlights on lowbeam so there are no extra wires. maybe a relay.
Old 09-13-2018, 10:40 AM   #4
hmsailor
Also, only my DRLs auto shut off but not my headlights. Gets annoying when your in a hurry and you have to look back and turn the knob.
Old 09-17-2018, 06:43 PM   #5
logoris
The auto shut off can be set at a Toyota, mine is set for 30 sec, you leave it on and 30 sec after shutoff all lights off
Old 09-20-2018, 04:34 PM   #6
hmsailor
didnt know that thanks. i need my karr alarm adjusted too. its too sensitive.
enable DRL at Yaris 2009-2011 Ot_tO DIY / Maintenance / Service 6 06-15-2012 05:13 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
DRL in Yaris from...? Falconia General Yaris / Vitz Discussion 3 02-25-2010 01:22 AM
Disabled drl and installed hids and now no fogs... 604yarisrs Cosmetic Modifications (Exterior/Interior) 10 02-14-2010 12:26 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
