#19 | |
Hmm, I see...
Drives: 2012 Toyota Tundra and Yaris Join Date: Oct 2016
I managed to fit a full size spare in the back of my 2012 Hatch, but the hybrids might have a different size
"Everything happens for a reason. Sometimes that reason is you're and idiot"
#20 |
Hmm, I see...
its a 15" wheel, tire is a 175/65r15 i believe
#21 |
Spare tire well riser removal
! I've puzzled over that thing...what it does and how to remove (for flat seat-deleted floor when 14" mini-spare goes on the front "bumper." )Did you hit a chisel between it and the pan where the spot welds are? Or just wack the riser itself? The holes shown in photos result, w/ no drilling involved?
#22 |
Hmm, I see...
I would recommend a Chisel...but i didn't have one in my hand so i just whacked and patched after lol. The holes are where the welds where. I didn't drill them out
#23 |
Might work w/ a ball-ish stone in a die grinder working down through just the riser piece at the spot welds. Then should be easy to knock it off and clean up pan w/ no holes?
(prolly easier than removing wheel cover anti-rotate keys on wheels that are never going to see a full cover...my Yaris doesn't have, but circa 1990 Miata and Corolla do.) |
#24 | |
Hmm, I see...
#25 |
![]() ![]() Drives: 2013 Hybrid 1.5L T4 Join Date: Jan 2011
As a quick update, i tracked down a 15inch full size wheel. I think it belonged to an older peugeot. It did it fit in the boot, yey since its not a space saver it atuck a bit higher up than the wheel hole so i lost some luggage space..but space saver wheels i found didn't fit due to hybrid having disc brakes on the rear. http://imgur.com/a/s4TPY
#26 |
I did notice that the bit you guys had to grind off/remove seemed missing already in mine.
http://imgur.com/a/Jo2ul |
#27 |
![]() ![]() Drives: 07 yaris Join Date: Dec 2016
I use a full size spare tire. Bit larger than a dummy tire but if I get a flat I can just throw it on and go with no worries.
#28 |
Good stuff, but its either the tire size i picked or dunno cos fromwhat ive. Read through other posts no one mentioned losing vertical space when fitting full sizw wheel. That isnt a plus with me, in fact i ended up removing thr parcel shelf
#29 | |
Yaris tower in spare tire well
(Wouldn't happen until the mini-spare is on the front "bumper") Last edited by dogsridewith; 12-10-2018 at 05:36 PM. |
#30 |
COOL now time to do this. good thing the entire car is some form of steel. and not aluminum.
| Changing to an MR2 Roadster Steering wheel | MESSIAH | DIY / Maintenance / Service | 2 | 05-03-2015 12:02 PM |
| Black/Grey OEM Leather Steering wheel question | heeroyuy01195 | Cosmetic Modifications (Exterior/Interior) | 12 | 10-14-2011 01:22 AM |
| Wheel Well Question | gwasabi | Cosmetic Modifications (Exterior/Interior) | 3 | 04-15-2009 12:09 PM |
| Question about wheel Offset | monoculusjoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 09-07-2006 03:03 AM |
| Wheel and tire question. | EddyCocaine | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 08-31-2006 11:13 AM |
