Drives: 2007 Yaris Sedan Join Date: Jul 2019
Oil Pan installation
I changed the oil on my 2007 myself for the first time (bought used last year). The Jiffy Lube (sticker on the window) tech stripped the drain plug, so I ordered a pan from Autozone + FEL-PRO Oil Pan Gasket OS30751. This is why I like to do my own oil changes, plus the filter was tightened on so tight I needed an Irwin expandable wrench to get it off
It came with 2 tubes of RTV sealant but the product description says it's for the upper oil pan gasket and the Fel-pro composite gasket is supposed to be installed dry. Is this correct. Obviously it didn't come with instructions as it's meant for pros not shade-tree mechanics like myself. Also, what's the torque for the bolts? I was going to pick up a torque wrench at Harbor Freight to do the job. Do you also think that the new drain plug that came with the new pan needs to be tightened? I'd just assume leave it alone. P.s. I have the Harbor Freight 302 piece socket set so I'm confident I can do the job myself. I think it's a 10 mm socket? Thank you fellow Yaris enthusiasts! Last edited by SF_Yaris; 05-24-2021 at 10:15 PM. |
Average KKT User
Drives: 2001 Echo Join Date: May 2020
The rtv I've always had luck with using rtv on one side of the gasket but I'm not a mechanic just a regular Joe Shmoe who takes on some minor repairs when needed.
The Toyota manual says 80-inch lbs (inch lbs not foot lbs they are very different)
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
use just rtv, those goofey gaskets are a waste of time and dont work well when aluminum mates with steel
![]() Drives: 2009 Toyota Yaris Sedan (blue) Join Date: Jul 2017
Does anyone know the part number for the oil pan bolts? I am replacing the oil pan and the bolts seem brittle...I have broken two of them so far :(
Average KKT User
Sorry for the long response time. I do believe 90119-06848 This is the right part number for the bolts 9 of them. Then two nuts which should be 90179-06326.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Oil pan threads stripped? | xdarkxfirex | DIY / Maintenance / Service | 2 | 02-22-2021 09:31 PM |
| Cracked Oil Pan | regal | DIY / Maintenance / Service | 21 | 09-22-2015 11:50 PM |
