Old 05-03-2009, 12:23 PM   #1
regal
Cracked Oil Pan
Hit someonthing in the road. Kept running fine, stopped at Autozone and there was tons of oil under the car, the oil pan was pretty mangled up.
What are the odds that the crankshaft/rod bearings are shot? Should I sell this wonderful little car?
Old 05-03-2009, 12:27 PM   #2
1. Did the oil light come on?
2. Was the car overheating?
3. How far did you drive after running over whatever it was?
4. Did you drive after stopping at Autozone?
Since there was oil coming out after you stopped, you might be fine -- it means you probably didn't run the car dry.
Old 05-03-2009, 01:09 PM   #3
regal
I had it towed after seeing the damage autozone, I drive maybe 5 minutes after the hitt to autone
I am more worred about the crabkshaft been damaged by whatever hit the oil pan
Old 05-03-2009, 02:19 PM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
If the block hasn't been damaged, you have nothing to lose by changing the oil pan and running the engine, with oil of course.
Old 05-03-2009, 02:22 PM   #5
ChinoCharles
Drives: LB
We can't give you advice without answers to those two, homie.
Old 05-03-2009, 04:21 PM   #6
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
next thread will be how his lowered height was to blame.........
Old 05-03-2009, 05:11 PM   #7
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Is your car lowered? I bet that's why it happened...
Old 05-03-2009, 05:12 PM   #8
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Our cars aren't designed for offroading.
Old 05-03-2009, 07:27 PM   #9
1NZYaris1
1NZYaris1's Avatar
Old 05-04-2009, 07:54 AM   #10
BLAZINBLUEVITZ
or it'll be another civic comparison......
Old 05-04-2009, 10:28 AM   #11
regal
So what do you think is my engine totaled, the oil light did come on till I killed it. My fear is theat the crank was damaged. Can sleep over this. Love the Yaris with the TRD suspension it was just a little more responsive/quick thatn I was prepared for.
Old 05-04-2009, 10:42 AM   #12
kurokoma-kun
Drives: 2007 Yaris HB
Have you talked to the dealer? Seems like they might be the best ones to evaluate the damage. I realize this is not a warranty repair but surely your insurance covers it.
Old 05-04-2009, 10:57 AM   #13
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Why dont you get a new oil pan and gasket, remove the old one, and inspect for damage? or have a machanic do it for you, we cant do much without pics or more detailed information.
Old 05-04-2009, 06:36 PM   #14
jkuchta
Drives: 2007 Yaris hatch (red)
My vote is put a new oil pan on it and make believe that the event never happened. If it was really only 5 minutes (and not 25...that felt like 5), then you should be ok, especially seeing as how the car had enough oil left to still bleed in the Autozone parking lot.
As far as the hit doing damage to the crank you don't have anything to worry about, as the block has a pretty deep skirt.
jkuchta is offline   Reply With Quote
Old 05-04-2009, 06:50 PM   #15
ChinoCharles
Drives: LB
Keep in mind if it locks up on you later a rebuilt/lightly used 1NZ costs peanuts.
Old 05-04-2009, 07:05 PM   #16
YarisSedan
Drives: 08 Yaris Sedan
If you were running synthetic oil than probally your engine is still fine. Few minutes with low oil pressure shouldnt cause engien damage. Especially since the motor did not sieze. Probally just punctured a hole in the oil pan causing a slow drip of oil. Replace the oil pan which takes probally only 30 minutes to do on our cars its extremly easy.
Then refill motor and see how it goes.
Old 05-04-2009, 07:57 PM   #17
06silveryaris
Drives: 2006 yaris
or was his suspension no name from ebay because then that caused it
but a a serious note it the engine wa not clanking heavily from the bottom or no oil light or overheating you should be just fine changing the pan
06silveryaris is offline   Reply With Quote
Old 05-05-2009, 12:51 AM   #18
regal
Thankyou much for the positive encouragement, The dealer said he also had to replace a sub frame member, not sure what that is. But is sound like I will be back in business tomorrow.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
