Old 10-24-2020, 03:43 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Oil pan threads stripped?
Since owning this car, i've done most oil changes at home. The last two times I was lazy and took it to two different quick lube places.
I decided to do it again today and noticed the drain plug is harder to turn when you loosen it, and when u tighten it. Its nothing crazy, but usually these things spin by hand freely when you loosen the torque on them. I pulled it out a few times and I didnt notice any shavings like it was stripped.
xdarkxfirex is offline   Reply With Quote
Old 10-25-2020, 07:20 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
They probably used an impact gun and cross threaded it. As long as it seals, it should be fine. If it weeps, apply a copper crush washer. My 'new to me' Kia Sedona came like that. Tight oil plug, with 'newly created' threads, again, likely from a ham-fisted tech somewhere. Never leaked and I did probably a dozen oil changes.
Old 02-22-2021, 09:31 PM   #3
xdarkxfirex
Toyota states 28ft/lbs torque. I haven't had a leak from the drain plug yet, and I changed the oil again last week. I used a tap and cleaned the threads up a little. Didn't see any shavings, but from now I guess I will just use my small 3/8" ratchet and forget my 1/2" ratchet
how to change oil pan b4mf74nk DIY / Maintenance / Service 10 09-01-2019 09:29 AM
Cracked Oil Pan regal DIY / Maintenance / Service 21 09-22-2015 11:50 PM
