![]() Drives: 2008 Toyota Yaris Hatch Join Date: Feb 2021
starter whirring before catching the flywheel
2008 Yaris 5 speed manual, 173k miles
So far its only happened a few times in the past week. I havent yet found a specific pattern to it, whether it does it when its hot vs cold, etc. But when i go to hit the starter the engine doesnt turn over, and i can hear a whirring. I wait about one full second and then the engine catches, and it starts up fine. To me it seems like either a tooth is missing off the flywheel, or the starter bendix isnt engaging correctly. I assume its the starter and I ordered a new one. Is there anything else I may have overlooked when trying to diagnose this? Also I have no clue where the starter is or how hard it is to reach but I assume i will find it somewhere around the bellhousing |
sounds like the typical sticking bendix, replace or re-grease
I guess thats what I'll do then. I changed a couple of starters before, I'm assuming its basically the same as honda or ford products.
| 2011 1.3 Yaris wont start-silence from starter motor | Biggles | DIY / Maintenance / Service | 2 | 02-10-2021 12:47 PM |
| Starter Problems - Heads Up | tmontague | DIY / Maintenance / Service | 6 | 03-01-2019 10:04 AM |
| 2zr Monkey Wrench Racing Light Weight Flywheel Review | tmontague | Performance Modifications | 15 | 01-09-2019 01:51 AM |
| Questions for new flywheel and clutch | mrbond | Performance Modifications | 11 | 07-11-2013 07:17 AM |
| Flywheel question-1nz conversion-2003 Model | Echo56 | DIY / Maintenance / Service | 0 | 05-21-2013 10:42 PM |
