#55 |
![]() Drives: Yaris Join Date: Oct 2008
I am planning to install a cheap kit in the yaris using the original stalk and relay in the inside part of the car. However, since there is no possibility of getting the adapted harness, could you tell me which kind of pins should be used to connect both lights to pin 1 and 2 in the relay box?
#56 |
dead links suck....
just got a "cheep" ebay kit and let me tell you what i got was on par with OE if not better...actual glass lenses, OE switch etc 40$ well spent after multiple passes thru this site digging for the hookup points on dash etc i eventualy figured it out |
#57 | |
![]() Drives: Mazda Join Date: Nov 2021
#58 |
![]() Drives: 2013 Toyota Yaris LE Hatchback Join Date: Aug 2021
Ok, I bought a new Stalk Switch. I'm just trying to find where the relay is located for my Daughter's 2013 Yaris. The loom connection for the bulbs are there. The fuses are in the fuse boxes that are identified as front Fog Lights. I'll buy whatever the f**k i need to buy for her car to work safely but the link you gave to micro whatever took me to a site when I clicked the Toyota Yaris tab it took me to a Nissan parts manual. Really appreciate a direction to get things for this vehicle. I see buying a Yaris in the Midwest is as bad as buying a Toyota in 1978 with respect to finding documentation on it. Everything is RHD.
At any rate any help would be appreciated. I can't find the damn relay or where it should be.on this 2013. Her 2010 was so much easier. After reading the entire thread, not realizing it went back several years and rhe Microimage has been closed for years now. Do I need to short any pins on the Stalk Switch connector? I bought a new switch with the Fog light switch on it for the 2013. It's installed as are a nice set of Fog Lights and Ultra 2 GTR Lighting LED fog light bulbs so I'd really like to get these fired up for her. Just can't seem to find the relay or where it needs to be installed. Last edited by Captamrica; 01-02-2022 at 08:16 PM. |
#59 |
Was hoping to find CTScott was still around since the last post on this thread was in 2016. His PM box has exceeded. It's storage cap so I'm guessing he's not around anymore. Guess I'll figure this out myself. Finding schematics on this vehicle sucks.
#60 | |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Totally pre-wired, no finding fog light relay nonsense. Even the indicator on the gauge cluster works.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
#61 | |
![]() ![]() Drives: 2015 Toyota Yaris LE Hatchie Join Date: Oct 2021
https://www.youtube.com/watch?v=drqpznBdnaw |
#62 |
![]() ![]() Drives: Yaris 2009 Join Date: May 2021
I am looking for a set of spotlights for long country drives.
SPOT vs flood Found these, opinions? https://www.amazon.com/dp/B088CXLV8K...ding=UTF8&th=1 OR https://www.amazon.com/AUXMOTEC-Driv...8mc7jI9Z8&th=1 |
#63 | |
if you want better country lighting get yourself some HID's for the headlights aim for 8000-10,000, and get a matching set of 8000+ for the fog lights, at that point youll never even consider auxillery lighting my wife has issues with her night vision and we do ALOT of night driving in the winter and its useualy deep out in he country, i tossed in a set of the bellow link and it was litteraly night n day, shes actualy speeding on the country roads instead of holding up traffic, added the fogs and hid'd them and even on the worst of nights visability is NOT an issue https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1 |
#64 |
They are unavailable.
I thought HID are illegal? https://www.powerbulbs.com/au/blog/2...20modification. What HID did you put in ONLY the foglights? I don't want to mess with my normal lights. |
#65 | |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
While there are HID conversion kits available that will replace the original H4 globes, they don't match well with the H4 reflectors, and will most likely not focus the light where you want it. Have you considered an LED light bar? There are brackets available that will fit on the front number plate mount for these.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#66 |
i did the h4 swap and they focused beautiffuly on the stock non hid reflectors nothing too high nothing scattered still nice clean edges
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Fog Light wiring | Rammy | DIY / Maintenance / Service | 0 | 11-08-2012 09:34 PM |
| viene viene FOG LIGHT IN Da HOUSE!!! | toro yaris pr | Caribbean | 27 | 07-18-2010 05:50 PM |
| My Yaris Fog Light | ezlove0710 | DIY / Maintenance / Service | 7 | 08-07-2009 07:15 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 11:42 AM |
