Old 10-26-2008, 12:26 PM   #91
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
OoOOooOOoo. I might be one of ten with the only aftermarket intake manifold for a looooooooooong time. Nice
Old 10-26-2008, 05:54 PM   #92
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I would be interested in an intake that had a flange for a larger throttle body. Anyone who has installed an intake on our cars sees how tiny the throttle body is on our motors. I think If we were to swap to a larger throttle body off like a TC or a corolla then there would be a much more noticible difference in HP
Old 10-26-2008, 06:06 PM   #93
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
I thought there was a plate for that?
bdc87 is offline   Reply With Quote
Old 10-26-2008, 09:05 PM   #94
richardholdener
Drives: 2008 Yaris hatch
The prototype intake was made with a flange to accept the larger Xd throttle body. The throttle body upgrade was only worth 1-2 hp-not enough to justify the expense of purchasing the new or used throttle body. Since I know whatthe next question will be (we've already covered this), the larger Xd throttle body will bolt onto the stock intake but sealing will be an isue since the hole in th eintake is much smaller than the hole in the throtle body. Ditton fo rthe rubber o-ring throttle body gasket. Besides, you will need to enlarge hole in th eintake which will be difficult since there is little wall thickness. An adapter plate can be made to facilitate the swap, but again cost versus power gain is not very favorable.
richardholdener is offline   Reply With Quote
Old 10-26-2008, 09:39 PM   #95
cee_dub2003
Drives: Scion xb
Originally Posted by richardholdener View Post
Air fuel is the same as stock intake since this motor has a mass air meter.
That is really hard to understand! For one the MAF only calibrates air volume and AIT temp. adding more air into each cylinder would cause the car to run lean, and ping, causing the knock sensor to draw back timing to compensate for the lean in tunr loosing HP.
I have seen a intake manifold for a TC do this. I would really like to see how you have done this when the Toyotas MAF is a very learing piece of equipment.
cee_dub2003 is offline   Reply With Quote
Old 10-27-2008, 12:53 AM   #96
richardholdener
Hopefully this will help you and others understand why your comments are somewhat inaccurate. The mass air meter is not a learning device, it is a simple measurement device that measures mass flow (temp, volume and infered density). The learning portion of the equation comes from the ECU (interpretation of signals from various sensors including MAF). Using a hot wire, voltage is applied to keep the wire at a given temperature. The greater the airflow (or lower the temperature of said air), the greater the voltage required to maintain a constant element temperature. This change in voltage (or frequency on some MAF applications) is correlated to airflow based on the relationship between ID of the meter assembly and what is refered to as the sample tube (flow orifice to hot wire element). The change in airflow through the system (that happens at different engine speeds and/or loads) is compensated for by the MAF. The same thing happens with changes in airflow from something like an intake upgrade. Problems can arise when you run out of effective meter range (we call this topping out the meter-meaning we reach the voltage ceiling near 5.0V). This can happen with major power gains like those achieved with a blower or turbo. We rescale the meter and combine it with larger injectors for these applications, but for something simple like an intake upgrade-there is no need for this. In reality, altering the mass air meter (by orientation, entry or alteration of ratio between flow orifice and metering orifice) will have much more of a change in the air/fuel ratio than adding the intake manifold. This knowledge on the workings of a mass air meter plus the actual data that came from the hundreds of direct back-to-back dyno tests run indicate that the air/fuel is not effected by the change in intake manifold on the Yaris. I make it a point never to bring speculation to a data fight.
Old 10-27-2008, 01:20 PM   #97
cee_dub2003
Drives: Scion xb
Thank you for clarifying that better for me. Sorry for the somewhat information information.
Old 10-27-2008, 05:14 PM   #98
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
ANd this would work on my '09 LB 1.3L engine, yes?
ZING is offline   Reply With Quote
Old 10-27-2008, 06:26 PM   #99
richardholdener
Intake has only been tested on 1.5L. NOt sure if 1.3L shares same intake config.
Old 10-28-2008, 09:21 AM   #100
ZING
ZING's Avatar
Old 10-28-2008, 09:05 PM   #101
Tamago
Tamago's Avatar
Drives: UZJ100
Unfortunately we lost a rod while running higher boost levels and .
what kind of boost levels were you running and for how long? help the 1NZ community out
Old 10-31-2008, 12:16 PM   #102
richardholdener
I am helping the community out by findin gout exactly what caused the probelm before jumping on the speculation bandwagon. The boost level did not hurt the motor nor the length of time spent at any given boost level. There had to be some type of ignition error that that resulted in excessive timing. We are looking into this and will report if we find the answer.
Old 10-31-2008, 12:24 PM   #103
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
got any pictures? Did the rod just break, bearings/melted piston?.... The H22 i have overspun the bearing and it popped a nice hole in the block...
Old 10-31-2008, 02:08 PM   #104
Tamago
Tamago's Avatar
Drives: UZJ100
ok i guess that's a non answer ;) stock 1NZ rods break on fully stock xA/B's due to high RPM's for extended periods of time. toyota fixed this by giving you Yaris people taller gears (better highway cruising) ..
if you read the write-up done by elprototypes on boosting the 1NZ the rods are the first things to go. the engine is over-square and offset crank which causes piston slap (which is obviously made worse by boost) and ultimately rod failure. there is no "speculation bandwagon" on the 1NZ.. it's been around almost 10 years..
is this your first 1NZ vehicle, Richard?
Old 10-31-2008, 02:31 PM   #105
I think by speculation bandwagon, he meant he's not going to speculate about his particular car within the context of what caused the failure. It is interesting that his failed under less than extremely stressful conditions, while mine has not failed after six months of driving at 8psi without any tuning whatsoever.
So, whatever he finds out will be interesting. A pic of the rod would sure be entertaining, in the meantime.
Old 10-31-2008, 03:16 PM   #106
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
don't mind him, he's just our resident scion ass paper who thinks his knowledge is helpful.....
Old 10-31-2008, 04:00 PM   #107
Tamago
Tamago's Avatar
Drives: UZJ100
better than being ignorant like you
Old 10-31-2008, 04:02 PM   #108
richardholdener
Thanks Rockland for the insight on the previous post regarding con rods-it is appreciated. Piston slap, offset crank pins-where do these guys come up with this stuff? I can remember when the light clicked on for me, the day that I realized that I didn't know everything and in fact knew very little. That is the day I officially started learning. Unfortunately, people put forth much more effort convincing others of their knowledge than actually obtaining it. For the record-Rod failure is caused by tension loads (rpm), extreme compression loads (detonation or extremely high power levels) or fatigue cycle life (extended operation near fatigue). Since none of the other situations were present-we must suspect detonation as the culprit, but will perform a post mortem to see if there is any evidence. The 1NZFE rods do not fail by design, neither did the Honda rods or small block Ford rods or any of the many powdered metal production rods-the culprit has almost always been a tuning error. There is a limit to the power production with the production rods, but since (in the case of this yaris) we were nowhere near that absolute power limit
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
WeSellCarParts.com // Weapon R Yaris Dragon Air Intake WeSellCarParts WeSellCarParts 19 12-27-2008 09:31 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
