toyota
RS stock page alert question..
how to i disconnect a wire from the car pager to the lights . i dont want a certain light to blink when i page my car...anyone.
its actually the park light i notice it blinks during the page.. anyone!! thanks |
toyota
bump anyone here has shots of the yaris car pager stock..connections and wire harness..??
toyota
#5 | |
(b) Answer-back function: • The main body ECU receives the door unlock detection switch's ON / OFF signals and uses these signals to confirm if the door control operation has been completed. The main body ECU then outputs the hazard warning light control signals to flash the hazard warning lights as an answer-back indication. It is considered to be a "customizable parameter", which can be changed by the dealer: 5. WIRELESS DOOR LOCK CONTROL SYSTEM Main Body (Main Body ECU) Display (Item) Default Contents Setting Hazard Answer Back ON When wireless lock switch on transmitter pressed, illuminates all hazard warning lights once. When unlock switch pressed, all hazard warning lights illuminate twice ON / OFF Wireless Control ON ON /OFF of wireless door lock function ON / OFF Panic Function ON Operates security alarm when panic switch on transmitter continuously pressed for 1 second ON / OFF Unlock / 2 Operation ON Function that unlocks driver side door when unlock switch on transmitter is pressed once, and unlocks all doors when pressed twice. if setting is OFF, pressing unlock switch once makes all doors unlock. ON / OFF Auto Lock Time 30 seconds Time until relocking after unlocking with wireless door lock function 60 seconds / 30 secondss |
toyota
i dont mind the hazards light flashing its the park light on the headlight that i dont want flashing..i guess i cant just disconnect a wire for it not to flash during panic mode..
reason i dont want that flashing is because im gonna use the park light wire to run my hid and headlight wire run the park light.. so ill have day time running light which is the park light and park light switch will run hid... |
#7 | |
my panic button flashes the headlights.
results: do not use the page. |
toyota
#10 | |
1. Have the dealer turn off the hazard flash option mentioned above. 2. Snip the wire from the ECU to the flash relay which goes to pin 25 on connector D33 (on the back side of the inside fuse panel). This would be a tough wire to get to and snipping it would have the same effect as #1 (nothing would flash when you lock/unlock). |
#11 | |
toyota
this is what im looking for cool thanks ill try this.
why is the page function so important to you ?
toyota
running the hid using park light wires i cant have it flashing..as far as i know flashing is not good for hid.. so my drl will be that small park light ( swapping headlight wire to parklight) and my head light/hid will be turned on by the park light wire.
but why would you want to swap those wires?
Pm me your email. My toyota mechanic sent me the wiring diagram for the whole headlight + DRL module, i'll forward them to you. Maybe this could help you with configuring your HID's. Are you running bi-xenon's or just single HID ? |
#15 | |
toyota
have you tried disconnecting the BLUE wire on the DRL module instead of unplugging the whole thing ?
what i have thought is connecting the ORANGE wire with a relay that will ground it when the handbrake is down... hence turning on the fogs at the same time... anyways.. i'm sure there are other alternatives than swapping cabling or disabling DRL. i still have to have time to play with all those wires. |
| FS: AFE drop-in filter and Stock Airbox with Cutouts | FunctionSpec | Items for Sale by private party | 16 | 06-02-2010 01:36 PM |
| STOCK SEATS OUT OF HB / stock tires/rims | mrrock | Items for Sale by private party | 19 | 08-19-2009 04:56 PM |
| Stock 6 disc MP3 deck + speakers for sale!!! | chino_potato | Items for Sale by private party | 16 | 02-05-2009 07:27 PM |
| noob question about stock tires | xCookiE | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 06-19-2007 08:40 AM |
| question about stock stereo wiring? | punch | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 07-19-2006 03:22 PM |
