Old 03-23-2009, 12:07 PM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
N/A?
Are there anymore options for N/A power? i did the I/H/E(Axleback) &Pulley.I am sitting on about $300 with nothing to gear it toward
Old 03-23-2009, 12:18 PM   #2
hatchbackkid82
Drives: .
1ZZ-FE throttle body. I think they go for $60, at least that's what i got mine for. Also you may want to get the Nitto mid-pipe, it would complement the axle back real nicely. Should see a lil' more power with those two mods and what you have
Old 03-23-2009, 12:19 PM   #3
Yoda
Yoda's Avatar
did you notice a power increase or just a lost of tq down low? think i might drive 2hours to get my car dyno today after i get off work at 2pm
Old 03-23-2009, 12:21 PM   #4
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
How do you drive your car? There's probably some more top end power to be gained by replacing the exhaust between the header and axle, but it's probably only going to show up above 5500-6000 rpm. In the real world, that just translates to numbers. "My car makes 100 whp on the dyno". Big deal. Unless you're drag racing, mid-range torque and throttle response is far more important.
If you're looking for more "daily driving" torque, about the only thing left to do is a lightweight flywheel and start shaving weight from the car.
Old 03-23-2009, 12:52 PM   #5
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Trust me, removing rear seats and getting rid of useless junk from the rear, definatly makes the car feel faster.
In my case, I removed nearly 100lbs from the back because of my 60/40 split seats.
Saved maybe 6 lbs total by replacing the front seats with racing seats.
It all adds up.
Old 03-23-2009, 01:59 PM   #6
hatchbackkid82
Drives: .
Exactly. Removing things like seats, carpet, sound insulation will make a difference. it won't necessarily make horsepower... the engine doesn't have to work as hard to get the car moving since your reducing it's mass
It all adds up.
Old 03-23-2009, 02:07 PM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
http://www.yarisworld.com/forums/sho...215#post272215
What a lot of people are waiting for.
Old 03-23-2009, 02:22 PM   #8
hatchbackkid82
Drives: .
Exactly
Old 03-23-2009, 02:37 PM   #9
Yoda
Yoda's Avatar
i drive my car as if it were fast... i use to drive a 00 Si after all so i am rev happy Soo you sayin i would need a mid pipe? do they make one for SD? Removing the seats are not practical for me tho i like the idea. Just looking to make some N/A power before i go FI a couple months later
Old 03-23-2009, 02:46 PM   #10
Loren
What?
Loren's Avatar
If your plan is to go FI, why not be patient and spend your $300 on something like a wideband O2 sensor rather than on something that might maybe net you 3 hp for a couple months?
Old 03-23-2009, 02:54 PM   #11
Yoda
Yoda's Avatar
.... you are right. Lets change that months to a year+ later lol
Old 03-23-2009, 04:03 PM   #12
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
No need to go drastic on the weight shaving area...
Taking the rear seat out and installing them out is a matter of 15 min.
Is not like you won't be able to seat anyone on the back of your car ever again...
I've taken mine in and out about 3 times now. If I know I won't be carriying anyone for a while I just take them out. Is really easy.
If you have the 60/40 rear seats... those are REALLY heavy!
When I go out for a spirited drive I even take out the spare tire and jack (If I'm not going too far away from home )
You can definetely feel the difference....
When I remove the back seat and spare tire I have to adjust the rear coilovers as the car will raise the back like 1/2 or more...
Old 03-23-2009, 04:05 PM   #13
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
"I drive my yaris like i had stole it!"LOL
If you install the 1ZZ-FE throttle body,
do u need a piggy back or any ECU changes???
harveyjai is offline   Reply With Quote
Old 03-23-2009, 04:17 PM   #14
hatchbackkid82
Drives: .
Nope after installing it just let the car idle for a little bit and it should re-learn the new throttle body. This is the case if you swpped over the chip that's in the TB as well. Really cheap mod $60 shipped. Hopefully you can find one for that cheap. don't know how much they go for on ebay
Old 03-23-2009, 05:08 PM   #15
jt258
jt258's Avatar
Drives: 10' corolla ce
HOW MUCH OF A DIFFERENCE IN SIZE ARE THERE BETWEEN THE 1NZ &1ZZ THROTTLE BODIES. HOW MUCH POWER DIFFERENCE CAN BE SEEN?
jt258 is offline   Reply With Quote
Old 03-23-2009, 06:56 PM   #16
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
dont yell, we can all hear you.
I think its almost a 1" difference, I have it but I havent measured it.
Old 03-24-2009, 11:15 AM   #17
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
1inch of a difference?!=.=
Old 03-24-2009, 12:23 PM   #18
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I have it installed and I did measure it
Stock 1.5
1ZZ 2.5
I have some pics but I' am not uploading them just to see that's 1" bigger
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
N/A stage 1 upgrade? forpinks Performance Modifications 12 03-18-2007 08:42 PM
