Old 05-10-2009, 12:31 PM   #73
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I was thinking about this oil cooler branded Flex-a-lite and includes a dual circuit and a remote fan triggered within a certain temprature threshold.
http://www.flex-a-lite.com/auto/html/remote-mount.html
Oil cooler 45901
Parmas is offline   Reply With Quote
Old 05-10-2009, 01:36 PM   #74
that's pretty fancy! -- is your oil too hot?
Old 05-10-2009, 02:05 PM   #75
Parmas
Parmas's Avatar
At least I am preventing it to be hot but as I said I am in doubt whether it will affect oil pressure.
Old 05-10-2009, 05:55 PM   #76
Unless there is a leak, your oil pressure should be exactly the same.
Old 05-10-2009, 06:26 PM   #77
Tamago
Tamago's Avatar
Drives: UZJ100
it depends on what part of the circuit he taps into for the cooler.
Old 05-10-2009, 06:37 PM   #78
Parmas
Parmas's Avatar
My intension of a using dual circuit oil cooler is that of using half of it after the oil pan and the other half for the transimssion.
Old 05-10-2009, 07:13 PM   #79
Tamago
Tamago's Avatar
Drives: UZJ100
you're going to cool the transmission gear oil? why?
Old 05-11-2009, 12:28 AM   #80
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
i think flex-a-lite is a very good brand as well, its a good choice parmas.
since it comes with a fan controller, you could skip installing an external controller like what i did. am using a pivot super temp here.
just curious, wouldn't you rather have a dedicated cooler for each engine oil and transmission?
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 05-11-2009, 02:40 AM   #81
Parmas
Parmas's Avatar
You are probably right in saying this but you have to consider the limited space I have in here. I think this oil cooler with it's active cooling is capable of keeping temps as low as possible I can get. Also it would be rather more expensive to get 2 independent oil coolers than a dual circuit one.
Re: ceramic coating... I done some research and there are many that say is a good asset to own heat management. Here is quite difficult to find someone to do the job for you and I don't wish to risk sending all the parts abroad and never come back! Although I really wish this coating I will keep you updated if I could find one somewhere...
Old 05-11-2009, 08:21 AM   #82
Tamago
Tamago's Avatar
Drives: UZJ100
so how are you going to pump the transmission gear oil through the cooler?
and "keeping the oil as cool as possible" is not smart. oils are designed to operate in a specific temperature range for them to be efficient. over-cool your transmission gear oil (not sure how you're going to pump it) and you'll end up with oil that just doesn't laugh, as you are heat cycling the oil constantly. leave the transmission alone, focus on the engine oil. if you want to keep oil pressures constant, i suggest cooling the oil coming OUT of the turbo (provided there is NO backpressure through the cooler).
Old 05-11-2009, 09:24 AM   #83
changchewsoon
Drives: Vios Turbo
just to clarify, we're talking about manual transmission here and not automatic right?
Old 05-12-2009, 02:00 PM   #84
Parmas
Parmas's Avatar
The choice of cooling the transmission is scrapped since the C160 can withstand high power and it is complicated to do aswell. Probably the oil cooler will be connected between the oil pan and the turbo.
Still trying to find someone who can do ceramic coating .....
Old 05-12-2009, 02:47 PM   #85
Tamago
Tamago's Avatar
Drives: UZJ100
just be careful to not pressurize the return flow to the oil pan. seriously oversize those lines, as you will blow your turbo seals if there's any backpressure on the oil return line.
Old 05-12-2009, 03:43 PM   #86
Parmas
Parmas's Avatar
What size do you recommend? Would oversize effect oil pressure?
Old 05-12-2009, 06:45 PM   #87
true; done that.
Old 05-13-2009, 08:27 AM   #88
Tamago
Tamago's Avatar
Drives: UZJ100
if the cooler is between turbo outlet and oil pan, oversize will not affect oil pressure.
it is highly UNrecommended to restrict oil coming back from the turbo, so if you do this, size it for 3times more than flow out of the turbo.
Old 05-13-2009, 10:18 AM   #89
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
I hate to add a pointless post to this great thread, but I need to subscribe.
Congrats on the progress Parmas and best of luck with the rest of it.
Wanted: Forced Induction
Old 05-13-2009, 12:28 PM   #90
I want to see this car on the road soon. Please.
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
