Old 05-14-2009, 09:22 PM   #19
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by mikenacarato View Post
+1, a guy at work blew a crank pressure sensor ($200) out of his maxima because the pcv valve didnt relieve the pressure and overloaded it, he had 150k on it though
sounds about right for a nissan.
Old 05-14-2009, 09:47 PM   #20
GeneW
Drives: 2008 Yaris
Did he drive it with a "Check Engine" light on? Sounds like it.
Gene
Old 05-14-2009, 09:51 PM   #21
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
idk. but an ignored pcv valve can cause issues is the bottom line lol
Old 05-14-2009, 09:53 PM   #22
Tamago
Tamago's Avatar
Drives: UZJ100
so the importance of changing the PCV is overshadowed by the importance of not being an idiot?
Old 05-14-2009, 09:56 PM   #23
GeneW
Drives: 2008 Yaris
Had a 86 Pontiac that consumed a quart of oil every 90 miles. Meant that I added a quart of oil PER DAY.
Once I discovered that the PCV valve was hopelessly sludged up - I'd checked it six months before and it seemed fine - I was able to cut consumption from a quart per 90 miles to a quart every three or four hundred miles when I replaced it.
Gene
Old 05-14-2009, 11:00 PM   #24
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
lol...I changed the pcv in my wife's corolla (pre-yaris) and the damn thing hand't been changed since the car was new....165k I grabbed it after removing the vac line....and it fell apart into the chamber in the valve cover...pissed me off...
Old 05-15-2009, 12:50 AM   #25
mimelio
Drives: NONE
At 50,000 I changed it on my 2002 Echo. Very easy to change $7.10 at NAPA.
mimelio is offline   Reply With Quote
Old 06-27-2009, 08:01 PM   #26
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
question I just replaced mine, but Im questioning i thought the one I took out was not all the way screwed into the block. I thought there was like two threads you could see between the nut portion of the PCV and the block it screws into. So I put the new on in to about the same point but now i'm questioning if that is what I saw or not..... Anyone recall who have have services this if it should be all the way to the block or if there is a gap. Ron
198K Miles
N9QGS is offline   Reply With Quote
Old 06-27-2009, 11:08 PM   #27
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The picture above looks like a tapered pipe thread. If so, I wouldn't expect it to screw all the way in. Just till it's properly tightened.
Old 07-07-2009, 08:12 AM   #28
SweetRS
Drives: 2006 Yaris Rs
funny this thread popped up, i went the the dealer an hour ago to ask the same question. they said at the time you change the spark plugs..which they said was 100k... i call bs on that time frame.
Iridium plugs only need to be changed every 100k....
SweetRS is offline   Reply With Quote
Old 07-07-2009, 02:19 PM   #29
Yaris Hilton
Smile
Yep. RTFM.
Old 07-07-2009, 05:25 PM   #30
mikenacarato
SIPNDEW
Drives: 15 STI
i wasnt referring to the spark plug change interval being bs...i was referring to the pcv valve being replaced at 100k, i believe it needs to be more like 50k
Old 10-22-2014, 03:41 PM   #31
danielastro28@yahoo.com
Drives: yaris.1.4
Hi guys,does someone has a pic of pcv valve location on yaris 2006.1.4 diesel.
danielastro28@yahoo.com is offline   Reply With Quote
Old 10-22-2014, 04:05 PM   #32
The 1ND-TV Diesel engine does not have a PCV valve.
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 12:38 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 10:27 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
