Old 05-18-2009, 07:08 PM   #19
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Russelt3hPirate View Post
why intercool it?
might as well make things easier and not intercool.
it'd be a lot cheaper too.
a car isn't turbo unless it has an intercooler. and it's not making real power unless it's a front mount.
didn't you know?
Old 05-18-2009, 07:21 PM   #20
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
loloolol, we don't know if you'll get det though from not running and intercooler... holdeners kit blew the engine when he was close to done tuning it with no intercooler...
Next im sure well get someone in here saying 6psi on a GT20 is the same as 6psi on a GT30 :D
Old 05-18-2009, 07:57 PM   #21
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by cdydjded View Post
Safer, makes more power, less likely for detination, easier is not better, what is cheap now will cost you more later
6psi, intercooler is a waste.
run meth injection instead.
Old 05-18-2009, 07:58 PM   #22
Tamago
Tamago's Avatar
Drives: UZJ100
not from me you won't
Old 05-18-2009, 08:28 PM   #23
Nexus1155
Drives: Audi
hahaha i really lol'ed when i read that tamago....... but he's got a point, meth injection would be a feasable option to stabilize the balance, it would be about the same amount of money it would cost for an intercooler and piping, if not less. AND it would be less charge travel through pipes so not much efficiency loss... I say he's got a damn good point...
Old 05-18-2009, 08:38 PM   #24
Tamago
Tamago's Avatar
Drives: UZJ100
=what is cheap now will cost you more later
you mean something along the lines of running half an FIC and unplugging the stock o2 sensor?
Old 05-18-2009, 08:41 PM   #25
Tamago
Tamago's Avatar
Drives: UZJ100
A front mount does not need to be refilled, I think the waste would be refilling that little bottle every other day. Your comment makes no sense , why would a cooler, denser air charge be a a waste? Please think before you answer, I do not generalities........
let's see..
small engine
small turbo
15 feet of intercooler piping
1 psi drop thru cooler..
just to be able to say you have a front mount?
i'm not anti-intercooler, i just think front mounts are retarded in low boost applications. even the supra TT came with simple side mount intercoolers FROM THE FACTORY.
and since when does one burn through 2 gallons of water/meth every other day? you don't know anything about meth injection do you?
oh and i find it funny you say you RAN a speed shop in miami. what happened? RAN? why not RUNNING?
Old 05-18-2009, 08:52 PM   #26
Tamago
Tamago's Avatar
Drives: UZJ100
Listen, based on your smart ass remark I can tell you never used a FIC & have a reading comprehension problem. The FIC has 4 programable maps. Fuel, Ignition, O2 & MAF. AEM recomends to use the least amount of maps. Right now I have control of Fuel & Timing. Im not running a turbo yet so there is no need to clamp the MAF or manipulate the O20 signal. So basically its installed & works. Also I did not unplug the stock O2 sensor, I unplug the connection from the FIC to the O2.
1. i have an FIC mounted and wired by me in my car.
2. iirc you already burned up your stock o2 sensor..
bad wiring?
Old 05-18-2009, 09:04 PM   #27
Tamago
Tamago's Avatar
Drives: UZJ100
Congratulation on havin a FIC, based on what facts do you claim I burned my O2?
I disconnected the connection to the O2 & still have a CEL, I might have screwed up the O2
and what happened to you being SO SURE that i know nothing about the FIC?
Old 05-18-2009, 10:07 PM   #28
Tamago
Tamago's Avatar
Drives: UZJ100
Is that the best you can do, answer a question with a question, your an empty suit
trust me, you don't want the best i can do.
good luck to you on your failing mission
Old 05-18-2009, 10:15 PM   #29
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
tamago FTL
Old 05-18-2009, 10:21 PM   #30
Tamago
Tamago's Avatar
Drives: UZJ100
Thats it? An ultimatum? Thats all you got? I want to see the best you can do, ohh I know you can put a panda sticker on you hood
i've already proven what i set out to prove, 65whp over stock, under $1000 spent.
and the panda is certainly not a sticker.
Old 05-18-2009, 10:28 PM   #31
Tamago
Tamago's Avatar
Drives: UZJ100
Wow good job, $1000 & 65HP, congrats, woop-t-doo! So if I do 66HP @ $999 & I better than you? King Tamago? Was the panda paint by numbers then?
you're joining the penis shit list.. i mean peterpoop..
g'bye and good luck yet again.. i'll keep an eye out for you looking for a replacement block after you destroy the one you're on now.
Old 05-18-2009, 10:32 PM   #32
Tamago
Tamago's Avatar
Drives: UZJ100
Now you look into the future & see me destroying my block, man your good, do you speak from experience? How many blocks did your $1000 turbo kit brake?
not a one.
let's see
my kit worked.
and you're still screwing around with an FIC
me 1
you.. 0?
Old 05-18-2009, 10:43 PM   #33
Tamago
Tamago's Avatar
Drives: UZJ100
Im an innovator, you a follower.....
you're innovating like crazy there
and if i'm a follower, i would have bought a kit.
Old 05-18-2009, 10:52 PM   #34
Tamago
Tamago's Avatar
Drives: UZJ100
Here is the definition for innovator, it 4 syllables, I know that might be a tough word for you:
"An innovator or pioneer in a general sense is a person or an organisation who is one of the first to do something and often opens up a new area for others and achieves an innovation"
I am the first to get the FIC to work.....you did not buy one cause your cheap!
you have NOT gotten the FIC to work. you have CEL's.
if you think what i did for my turbo setup is not innovative, then not my problem??
Old 05-18-2009, 10:58 PM   #35
Tamago
Tamago's Avatar
Drives: UZJ100
cool, good luck to you.
Old 05-18-2009, 11:18 PM   #36
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
your not the first to be running it i have been running it for 2 months now successfully
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Chino's Turbo Thread ChinoCharles Forced Induction Forum 299 03-17-2017 08:01 AM
GI: Turbo Manifold ChinoCharles Forced Induction Forum 4 04-13-2009 01:42 AM
xa/xb Turbo manifold for Custom set up CASTREX Forced Induction Forum 1 01-21-2009 02:43 PM
Why industries turbo manifold? anonymous user Forced Induction Forum 33 12-07-2008 01:11 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
