Old 05-27-2009, 11:41 PM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Still trying to get a power wire through firewall..
Iv searched and searched on the forums here, best "nipple" i see that is easy to get to is the one above ecu on passenger side but i want to have my power wire as short as possible to amp, so either going pass the drivers side which i still cant find a nipple to get through or under the car. Any helps?
Old 05-27-2009, 11:55 PM   #2
There's a huge bushing on the drivers side where a large harness goes through:
Old 05-28-2009, 12:39 AM   #3
ezhacker1
ezhacker1's Avatar
Originally Posted by echo_hrs View Post
If you follow the main harness in the engine compartment, it goes through a huge rubber grommet on the driver's side that has extra nipples...I taped my 8 gauge wire to a hangar and poked it through there...
Cheers
yeah thats the thing i just couldnt find, or anything. Compared to my 98 taco, this is crazy...
Old 05-28-2009, 01:55 AM   #4
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
iwent through my fender and in threw where there was a hole next to the fuse box. i think i have a picture somewhere i'll post it up.. havent had any issues and it isnt near any moving parts that could cut/kink it
Old 05-28-2009, 01:57 AM   #5
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
if i remember right i put it threw and into that big grommet from the door electronics. and just ran it thought there.
Old 05-28-2009, 12:03 PM   #6
to get at the nipple on the drivers side, you have to take apart the wipers and the tray there...thats what i had to do to install the power wires for my fogs....kind of a pita, but worth the effort...
Old 05-28-2009, 04:16 PM   #7
ezhacker1
ezhacker1's Avatar
that helped extremely!!! i gave up trying to go through the firewall, even tho i was 90% done with removing wiper and tray.
go through the door grommet outputted it right next to the door sill cover excellent. thanks a bunch.
Old 06-01-2009, 11:40 AM   #8
pariahdecss
Yarisomniac
pariahdecss's Avatar
Drives: 2009 5spd LB
I think talnlnky and others have alluded to this in other posts, but running power through the fender (grommet or not) is a really bad idea. Any location that exposes the wire to unnecessary chafing or weather is asking for trouble - electrical shorts / fire/ general electronics mayhem. Not trying to be a jerk just trying to save you some grief
There are firewall grommets on both the passenger and driver's side that fit the bill. I ran 4 gauge through the driver's side grommet that CTScott has in the pic
Last edited by pariahdecss; 06-01-2009 at 11:44 AM. Reason: chocolate bunny rabbits
pariahdecss is offline   Reply With Quote
Old 06-01-2009, 01:19 PM   #9
severous01
i agree with pariah.....bad idea. plus you look like you have no idea what you're doing when people see that kind of wiring...sure it works and it will for a while....but it just looks really bad. i make fun of honda guys for doin that kinda stuff...
Old 06-02-2009, 03:46 AM   #10
ezhacker1
ezhacker1's Avatar
really now... ill have to re-look. I didnt think it would be a problem.
Old 06-02-2009, 04:25 AM   #11
IsLNdbOi
IsLNdbOi's Avatar
Cheers
When I installed my electrochromatic rear-view mirror, it took me hours to get the harness for the temperature probe through that grommet. I taped the wire for the harness to a wire hanger and after a couple of hours of trying and multiple holes punctured through the grommet, I finally got it through.
I also managed to crack a piece of that plastic in the engine bay that covers the wires coming into that grommet.
I hope others have better luck than me getting through that thing!
Old 06-02-2009, 10:17 AM   #12
pariahdecss
Yarisomniac
I pulled the battery out to make access to the driver side grommet a little easier, it was tight but did not take all that long. I also upgraded the battery ground to chassis cable so it made sense to pull the battery anyway.
Old 06-02-2009, 10:30 AM   #13
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I paid a stereo installer $40 to drill a hole through the firewall under the dash and put a 1/2" grommetted hole there. I am able to run two 4gauge power wires, and three sets of wires for gauges.
It was a very easy $40 to part with considering how fast he got it done and how I had no clue how to do it safely.
Old 06-02-2009, 10:57 AM   #14
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
...drill a hole through the firewall under the dash and put a 1/2" grommetted hole there.
That's what I'll be doing when I have to start running all my power wires. I don't get why everyone is torturing themselves trying to find ways to run wires. Pick a spot where you want the wire to go and punch a hole in it (as long as you know what's on the other side!)
Old 06-02-2009, 12:35 PM   #15
severous01
http://www.painlessperformance.com/w...rchField=40106
here....
Old 06-13-2009, 10:47 AM   #16
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i was cleaning the yaris yesterday and felt ambitious enough to rerun the power cable through that huge mother grommet. took FOREVER to get it though the nipple that is there.. but eventually i got it through :)
Old 06-13-2009, 10:48 AM   #17
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i dont think there would have been a problem at all.. Just felt like messing around with it :)
Old 06-14-2009, 01:42 PM   #18
dccurrent
Drives: Yaris 5 door Liftback
Damn man for like 50 bucks you could have gotten a sub and amp installed as well. 40 bucks sounds steep for just a hole but if you're happy then by all means.
dccurrent is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 03:12 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Running Firewall Power Wires for subwoofer MacMaster761 In Car Entertainment + Electronics (audio / video / alarm) 17 03-06-2010 04:04 PM
Power wire gauge vs stereo wattage goku87 In Car Entertainment + Electronics (audio / video / alarm) 1 02-24-2009 03:16 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 02:05 PM
