Old 06-07-2009, 04:21 PM   #37
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Morgan View Post
I'd like to see a small turbo, simple set up done on a yaris and I honestly hope it works out for you which ever turbo you choose but I just want to see it done not just discussed. Seems to be a general consensus that it could be done but then again in theory the xa/xb transmission should work too - it sucks to be the first one to jump in and get it done, but at least you'd know exactly how/why it did or didnt work
sorry friend :(
Old 06-07-2009, 04:22 PM   #38
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
YOU REALLY REALLY should just shut the F up at this point.
you don't understand in the LEAST how VVTi and knock sensors work, do you?
lol now this is getting fun...
So I bring up a valid point about timing and you're answer is to leave it to the knock sensor?? Seriously? So since I have no idea what I'm talking about, maybe you can explain what the ECU does when it detects knock. Pull timing right? Right...but how much? Until it stops knocking? Do you know how, pun intended, retarded that sounds? The knock sensor is designed to pull timing based on IAT's, variances in octane, and a few other factors...not to make up for not having the proper values in the timing map to reference in relation to positive pressure.
I'm going to pretend that you didn't mention VVTi seeing how it has no relevance here. But maybe you can explain that one too.
The Spectacle is offline   Reply With Quote
Old 06-07-2009, 04:27 PM   #39
Morgan
Morgan's Avatar
Drives: 07 MM LB
sorry friend :(
its ok, but now I know that an xa/xb transmission will fit but not work in a yaris
Old 06-07-2009, 04:36 PM   #40
Tamago
Tamago's Avatar
Drives: UZJ100
you have no experience with forced induction in the 1nzfe.
i do
i know what works safely.
you're going on my ignore list, not worth my time answering your retarded arguments.
Old 06-07-2009, 04:45 PM   #41
The Spectacle
Drives: 08 BSP LB
i do
Cute. Guess I got under someone's skin lol
Anyone else venture to go toe to toe with me on the merits of boosting a car without proper engine management? I've got nothing else to do today.
Old 06-07-2009, 04:54 PM   #42
Nope, not going to argue with an armchair expert with respect to the 1NZ-FE. I have other stuff to do today.
I've never recommended jumping into a turbo project without being clear on the risks to your motor and your wallet. You haven't read many of my posts if that is what you think.
Old 06-07-2009, 05:09 PM   #43
The Spectacle
Drives: 08 BSP LB
You guys talk about having experience with the 1nz-fe like its some kind of technical marvel. Its a 100hp motor for god sakes.
Old 06-07-2009, 08:58 PM   #44
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
And what experience do you have and on what cars pray tell? I'd love to hear your adventures
Old 06-07-2009, 11:16 PM   #45
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
need i quote the line?
ka0sx is offline   Reply With Quote
Old 06-08-2009, 12:27 AM   #46
"you have failed me for the last time, captain"?
is that right? do I win something?
Old 06-08-2009, 01:10 AM   #47
ka0sx
ka0sx's Avatar
if i ever see you in person i will hand you a stale old cookie =P
that is the actual line from the scene, but i was refering to the "motivational" version "i find your lack of faith disturbing"
refering to
who apparently is oblivious to the amount of engineering that goes into a modern engine. Especially no credit is given to the software and computer engineering advances that allow these engines to act and adapt in such a versatile fashion.
Old 06-08-2009, 02:14 AM   #48
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
*subscribed* :)
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 06-08-2009, 12:00 PM   #49
Tamago
Tamago's Avatar
Drives: UZJ100
refering to
and the fact that it makes some of the best hp/lb of ANY engine in any car in the world.
Old 06-08-2009, 12:50 PM   #50
06silveryaris
Drives: 2006 yaris
I do not know what is the big deal when someone wants to do "something out of the norm" or not buying some "kit",of course it would work with no intercooler and an after market piggy back or ecu. Just do bigger injectors.I have seen people here do that with Hyundais Brio and Mitsubishis mirages they even get pipes done cheap at a mufflershop. Doesn't look pretty all but it works. For a low boost aplication it will be just fine. budget turbo the butt dyno is happy and so is the wallet.
06silveryaris is offline   Reply With Quote
Old 06-08-2009, 01:27 PM   #51
Tamago
Tamago's Avatar
Drives: UZJ100
if i were to do it again, i'd trade engine management for a good solid water/meth injection setup. (on low boost)
Old 06-08-2009, 02:38 PM   #52
Yeah after reading more on here (special thanks to Morgan for actually doing it), I probably would too. May still get around to it.
Old 06-08-2009, 02:40 PM   #53
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
It's a Garrett. Comes off a Saab 9-3 and are pretty easy to come by.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 06-08-2009, 05:26 PM   #54
Morgan
Morgan's Avatar
Drives: 07 MM LB
worth every single penny! good for cooling and reduces knock, what could be better? HIGHLY recommended, especially if you don't end up using a piggy back or some type of other engine management!
(yes, you could probably tune it out if you can advance your timing, but I can't so instead I use it as a safety feature not for performance)
Small cars stacked up at dealerships. freeridelectric New YARIS Purchase Forum 11 04-24-2009 08:23 AM
Small car's name? yaris-me Off-topic / Other Cars / Everything else Discussions 13 03-29-2009 02:43 PM
Small science fiction story I wrote which includes the Yaris. :) john21031 Off-topic / Other Cars / Everything else Discussions 3 11-21-2008 12:57 PM
How Small Would You Go? Nigal General Yaris / Vitz Discussion 26 06-15-2007 08:44 PM
small 4ch amp. 4x100rms ben dover In Car Entertainment + Electronics (audio / video / alarm) 2 04-08-2007 04:17 PM
