#55 | |
#56 |
XBL: Jeemee Ghost
It's a Garrett. Comes off a Saab 9-3 and are pretty easy to come by.
_________________________________________________ Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers |
#57 | |
(yes, you could probably tune it out if you can advance your timing, but I can't so instead I use it as a safety feature not for performance)
#58 | |
#59 | |
Who said Yaris was slow?
![]() Just kidding Is not that simple. It depends on the turbo you use and your set up. So there is no way to say x amount of HP per psi. You could said though that for any given set up the car puts out xamount of HP for psi. That would be true within a psi range. IE: If Garm's old set up made 180hp at 8psi and lets say the base power was 100hp, then you can said his turbo made 10hp per psi. You can also assume that the same set up at 10psi would put out 200hp. As the PSI goes up and you start going out of the effeciency area or the turbo, the numbers will change (decrease)... |
#60 | |
So you can have th everyday map for regular gas, then a Meth map and finally the all out race gas map. The Meth map comes pretty handy when you want to have some fun and don't have some VP handy... or if you don't want to pay the race gas price. 240-250whp for every day driving on regular gas 260-270whp on meth 300+whp on race gas |
#61 | |
Now I've heard it all.
#62 |
the next person that uses the term "slap on" in the same sentence as "turbo" needs a permaban.
#63 |
SIPNDEW
spectacle needs a permaban..........we already have enough bs on the forum as is.
#64 | |
Maybe in 3-5 years, when a lot more people have tried and either succeeded or failed, the question can be answered with some data to back it up.
#65 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Has anyone ever told you that you know nothing about cars? or is that a first too!
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
#66 |
Its a first.
#67 |
SIPNDEW
#68 |
bench racing = real-life, knuckle-skinning experience, didn't y'all know? that's why we can "slap on" turbos and coilovers....
#69 |
lol @ the bashing on spectacle.
#70 |
#71 |
![]() ![]() Drives: 1990 Supra Turbo Join Date: May 2009
I don't have any experience with a Yaris, let alone a turbo one. But, I do have a turbo supra.
Here are some of the basics that I know about Turbo cars. Please let me know if I am wrong though. -A car with a Turbo stock will have an ECU that is set to retard timing at higher rpm / higher boost. -Turbo cars have much lower engine compression and are better able to handle boost. -NA cars try to achieve a Air/Fuel Ratio of about 14.7, probably richer than that at about 13-14 or less when at full throttle. -A Turbo cars ECU is set to run at 11-12 AFR at full throttle. Running richer allows the gas to cool the piston and reduces the risk of detonation. -Turbo cars usually have some or all of the rotating assembly forged. So, basically, running a turbo without any modifications on an economy engine, you will detonate with AFRs around 14, even at 7psi. I hope someone before me set you guys straight but this thread looks like Honda Tech. It's just horrible. |
#72 | |
when the car goes into open loop mode, larger injectors will provide more than enough fuel to keep boost mode cool
| Small cars stacked up at dealerships. | freeridelectric | New YARIS Purchase Forum | 11 | 04-24-2009 08:23 AM |
| Small car's name? | yaris-me | Off-topic / Other Cars / Everything else Discussions | 13 | 03-29-2009 02:43 PM |
| Small science fiction story I wrote which includes the Yaris. :) | john21031 | Off-topic / Other Cars / Everything else Discussions | 3 | 11-21-2008 12:57 PM |
| How Small Would You Go? | Nigal | General Yaris / Vitz Discussion | 26 | 06-15-2007 08:44 PM |
| small 4ch amp. 4x100rms | ben dover | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 04-08-2007 04:17 PM |
