Old 06-08-2009, 03:27 PM   #19
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by largeorangefont View Post
Yes and Subarus as well. Like I said.. you just have to be smooth. I've only done it on the track though, not on the street.
Yes if you start stabbing at the brake pedal, you are going to lock the wheels.
ahh, well you're good then!
Old 06-08-2009, 03:55 PM   #20
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
i didn't realize there was a difference (abs deactivated vs non-abs), but that makes sense seeing how abs needs to pump the brakes so rapidly
abs really gets in the way on smooth and dry surfaces, where it's not needed so much, but comes into play anyways.. on gravel and wet, it has it's ups ;D
Old 06-08-2009, 03:56 PM   #21
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
No real point in disabling it for the street though. It is no fun driving around on D shaped tires.
I locked the front wheels once in the Yaris (non ABS car) and flatspotted the front tires in a panic brake situation from 90 to about 30. It put a bad flat spot on the fronts.
Luckily I needed new tires anyway.
Old 06-08-2009, 03:58 PM   #22
largeorangefont
Break'em off some.
The non ABS cars have a more linear brake feel so you can modulate better.
ABS cars are generally have more boos and are less linear to give lots of brake with minimal pedal travel, and the ABS will modulate if necessary.
Old 06-08-2009, 04:07 PM   #23
Tamago
Tamago's Avatar
Drives: UZJ100
i'd like to see someone out-brake my ABS with EBD on dry pavement :D it's superb, in fact i genuinely feel that in a straight line, current ABS systems will easily out perform the average driver's foot
Old 06-08-2009, 05:36 PM   #24
largeorangefont
Break'em off some.
I agree. the key word is average.
Old 06-08-2009, 05:54 PM   #25
Tamago
Tamago's Avatar
Drives: UZJ100
how many above average drivers are in this thread? not me!
rubbing up front under heavy breaking regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-12-2009 12:23 PM
heavy braking regal General Yaris / Vitz Discussion 8 05-12-2009 11:45 AM
ACT Clutch Kit 2007+ Toyota Yaris Heavy Duty 6 Puck trini_per4mance Items for Sale by private party 0 12-20-2008 12:16 AM
A little Culture (heavy on the bandwidth) GeneW Off-topic / Other Cars / Everything else Discussions 0 11-21-2008 04:50 AM
How Heavy is the flywheel? jouslee DIY / Maintenance / Service 12 02-22-2007 02:18 PM
