Old 06-23-2009, 12:58 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
would 16x8 with +25 offset fit on the rear?
would 16x8 with +25 offset fit on the rear without rubbing when car is full?
Old 06-23-2009, 01:00 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
what tire?
i'm wagering NO, not without some camber added or some fenders pulled.
Old 06-23-2009, 01:26 PM   #3
AlainMikli
AlainMikli's Avatar
NO!!
I have 16x7 +42 offset all around, 15mm spacer on rear, stock camber on rear, front should be like 0.5 more than stock.
I already rub the front in full turn
I rub the rear in some small bump, even with no passenger!!
I've try e passenger with me at the same time, super rub even on local...
I think you have to run a large camber..if you want to run 16x8....
but still need to see how low you are
To do: Supercharger…
Old 06-23-2009, 01:30 PM   #4
marcus
toyota
marcus's Avatar
thanks...so 16x7 +40 on the rear its safe to put 10mm spacers to get zero rub even when full but i may be runnign 195 on the tires. assuming u got 205s
Old 06-23-2009, 01:46 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
yes, an effective +30 and a 195 tire you'll be fine with a X7 width
Old 06-23-2009, 05:21 PM   #6
AlainMikli
AlainMikli's Avatar
I'll rub the front a little bit, when I push it hard in some corner, but you should be fine if you run some 195 tires
Old 06-23-2009, 05:25 PM   #7
marcus
toyota
marcus's Avatar
im thinking of staggered set up front 16x7 +40 offset and then rear 16x8 +25 offset car is in trd spring but may switch to df210 later on. plus camping month the car get full so i dont want rubbing on the fenders..
Old 06-23-2009, 05:54 PM   #8
kngrsll
Apexing Egg!!
kngrsll's Avatar
i have 15x7 +25, no rub. i could actuall use a spacer in the rear (i have some camber too)
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-23-2009, 06:04 PM   #9
Switch to DFs and you won't have a hope in hell of avoiding a rub. Most likely going to happen on the current TRDs.
BTW - this is your 3rd 'rub' thread isn't it?
Old 06-23-2009, 06:07 PM   #10
AlainMikli
AlainMikli's Avatar
here is some pic of mine, 16x7 +42, 15mm spacer in the rear
if you run 16x8 +25...you should be (0.5"+2mm) more flush than mine at the rear.....
i think you should be rub when your car get full..... (with the stock camber)
Old 06-23-2009, 06:12 PM   #11
AlainMikli
AlainMikli's Avatar
he just don't want to get rub
Old 06-23-2009, 06:15 PM   #12
marcus
toyota
marcus's Avatar
maybe the 3rd ..sound about right but really i havent got the rims..i was ready to get them but local dealer cancelled with drag wheels due to shipping issues so im back to the drawing board..now a dealer offered me staggered rims so im trying to figure this out..its good for others as well.. all i know so far.. 16x7's zero rub on +40 offset assuming u used 195's/50/16..for the front.
but the way the rubbing issue is on the side of the fender..so trd or df210 should not make a difference if u got the right offset and tire size.. 2 person on the back on the trds tucks the tire on the fender..just like that.
Old 06-23-2009, 06:24 PM   #13
AlainMikli
AlainMikli's Avatar
i'm not lowered by spring, so may be yours are little bit higher than mine, but softer....
Old 06-23-2009, 06:29 PM   #14
marcus
toyota
marcus's Avatar
i find trd / eibach pro kit i believe really soft..which maybe a good thing most of the time.
Old 06-23-2009, 07:29 PM   #15
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Sorry to nitpick, but shouldn't this be in the wheel/tire area?
Old 09-15-2009, 03:43 PM   #16
etheliters
etheliters's Avatar
Drives: 07 yaris hatch
I'm interested as I'm putting 16x8 on rear of my lb. Pretty sure I'm gonna roll the fenders. How much should it cost?
etheliters is offline   Reply With Quote
16x7 +38mm front, 16x8 +0 rear WILL IT FIT? wildmongoose26 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 02-23-2014 11:04 AM
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
