AKA Samurai Racer
wheelspin problem
hey guys
i got a problem i'd like to get rid of when i go hot into a corner , and try and give alot of throttle , the front wheels just start spinning , will a sway bar help with keeping the wheels down , here is my setup: Tein super compact coilovers - 6 front - 8 rear - setting Tananbe front strut bar 17 inch michilen pilots 205 / 40 /17 tire pressure - 2.4 bar ( nitrogen ) |
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
you do have low profile tires, maybe running on 16s or 15s might help. The sway bar will help your rear end out, at least my friend w/ the Forester says it does for his~
Whats 2.4 bar? what psi is that? I usually run 42psi on my fronts, they spun out couple times under heavy liftoffs lol.. |
LSD
#4 | |
AKA Samurai Racer
AKA Samurai Racer
Wouldn't a bigger side wall cause more tire wall roll?
I say a rear sway bar and stickier tires, and if you can afford it, an LSD (expensive!). |
#7 | |
AKA Samurai Racer
correct , bigger sidewalls cause more movement !! i forgot bout that !! thx
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
If both wheels are spinning get new tires.
If only/mainly the inside wheel is spinning then it's probably lifting and a big rear sway bar should help. |
sometimes you have to go slower to drive faster....
#11 | |
AKA Samurai Racer
yeah , i was thinking the same thing , big rear sway bar !! one from Garm ;-) |
AKA Samurai Racer
LOL , true dat !!! i got a heavy foot aswell , hehe !!
well, when you corner hard, the weight transfers to the outside wheels.....so if you're tossing it into the corner too hard and hammering the gas, it doesnt matter how flat your suspension lets you sit, youll still light up the inside wheel
#14 |
Who said Yaris was slow?
Like mentioned in the above posts... First you need to tune the driver!! You already have a VERY capable coilover suspension!! On a FWD car you need to keep momentum thru the turns a get a good feel of how the weight transfers from front to back... No matter what suspension you have you can not go full thottle on the curve... you will lift the inside tire no matter what! Practice...! You jave to be smooth on the throttle while going out of a turn. Once you have yourself dialed in you can start playing with the suspension. Try soften the front and going stiffer on the back... play with tire pressures also... higher pressure on the back... The rear sway bar will be a great improvement... After that if you are still seen alot of wheel spining you can go with a mod that Loren suggested. Disconect the front swaybar of the car. Make sure you look up Loren's thread first so you understand what are the pros and cons of this mod. And finally, the LSD. A great but usually pricy $$$ modification. |
#15 | |
![]() ![]() Drives: '07 3 Door Yaris of Doom! Join Date: Dec 2006
#16 |
AKA Samurai Racer
thanks for the imput guys , really appreciate it !! always so good chatting on this forum !!
yeah , i have been trying to spin the wheels on purpose to see what the limits of grip etc are. i think a sway bar in the rear would be the next upgrade to do for sure , and possibly a bit more grippy tires. i must say , when i do keep it smooth , the Teins perform really wheel , and really come to life on mountain passes. i got a few more power upgrades to do , and looks like a local tuner will get the Unichip Q from Dastek to work on my car well. so loads of development to go , and having fun doing it. |
#17 |
AKA Samurai Racer
yeah , you right , they are pretty high , but i keep them little higher as we have bad roads with crappy potholes lately , so trying to protect the wheels a bit more. |
| electrical problem with car need help badly!! | Adriaan | DIY / Maintenance / Service | 20 | 05-07-2010 12:40 AM |
| Gas pedal problem? | Befuddled | Performance Modifications | 28 | 01-27-2010 09:55 AM |
| Brake problem | 1saneguy | General Yaris / Vitz Discussion | 15 | 11-24-2008 03:56 AM |
| HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 06:00 AM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
