Old 02-22-2010, 07:17 PM   #19
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by cdydjded View Post
2) The AFM is mounted to the inlet of the turbo, which means is sucks through the AFM. I feel its better to blow through the AFM, just my opinion.
if it were better to blow through the AFM, don't you think Subaru would have done this on their STI? (same part number MAF as the yaris)
Originally Posted by xnamerxx
you nailed it sir.
Old 02-22-2010, 07:20 PM   #20
Tamago
Tamago's Avatar
Drives: ZZW30
The problem is the following, the oil feed is high pressure in, the return is low pressure gravity feed. What is happening since the return is low in the pan it uses the suction of the oil pump to flow oil. When you are accelarating there is no problem, high pressure in, suction through the oil pan. But at low speeds or between shifts there is not enough suction/flow out of the turbo so you get oil creaping through the seals in the turbo. At that give a little puff of smoke through the exhaust. The best way is up high in the top part of the pan. That way the oil will just flow out of the turbo & into the top of the pan above the oil in the pan.
i ran a -8 return line directly into my pan with absolutely no flow problems.. welded a -8 JIC 90deg fitting facing backwards to the "side" of the pan. proper return line sizing is more of an issue than where the oil flows to.
you nailed it sir.
Old 02-22-2010, 07:23 PM   #21
cdydjded
Drives: Yaris LB Turbo
When going from non turbo to turbo, my opinion is that it is better to blow through than suck through. I used the advise & extensive Toyota knowledge of Lance from Toyomoto & Brandon from PSI Racing. Subaru can put the AFM where ever they want & so can I.
Old 02-22-2010, 07:23 PM   #22
Tamago
Tamago's Avatar
Drives: ZZW30
fair enough. as long as your IAT's aren't through the roof post-turbo, i'm sure the stock MAF will be just fine
you nailed it sir.
Old 02-22-2010, 07:27 PM   #23
cdydjded
I also have a -8 return line. But as you stated you welded the bung on the side on the pan, the Zage pan has the hole in the front of the pan in a 45 degree angle.
Old 02-22-2010, 07:42 PM   #24
Tamago
Tamago's Avatar
Drives: ZZW30
well that's just dumb of them lol..
you nailed it sir.
Old 02-22-2010, 10:02 PM   #25
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
umm ok you have to remember i am noob to this whole oil pan thing. So are there two taps in the oil pan? one for feed one for return? Are you sayin that the return line needs to be further up the top of the oil pan so gravity can take the oil from the turbo back down to the pan?
So if the oil flow through the return is not good it can lead to a build up in the turbo and will breach through the seals?
Would like to get it right the first time...synthetic oil not cheap lol.
Again pictures whould really help clear it up when you guys have the time
Old 02-23-2010, 01:09 PM   #26
Tamago
Tamago's Avatar
Drives: ZZW30
the feed should come off the front of the engine, where the oil pressure switch is.
you nailed it sir.
Old 02-23-2010, 05:07 PM   #27
Yoda
Yoda's Avatar
have no idea where the heck that is....i am thinking this part of the install gonna give me the most problems
Old 02-23-2010, 06:31 PM   #28
^ the Yaris service manuals are your friends, you should be sleeping with them under your pillow.
Old 02-23-2010, 11:49 PM   #29
Yoda
Yoda's Avatar
lol ha will do
Old 02-24-2010, 04:36 PM   #30
Yoda
Yoda's Avatar
Having a bit of problems getting back in contact with zage.... No response to email and number not working. Can someone else try. I need a final price on the kit
Old 02-24-2010, 04:53 PM   #31
Tamago
Tamago's Avatar
Drives: ZZW30
1. buy the HKS kit
2. have a local shop (CFT) modify the downpipe
3. have CFT tune it
4. DONE
i feel like i repeat myself a LOT in the forced induction forum here..
you nailed it sir.
Old 02-24-2010, 04:57 PM   #32
Yoda
Yoda's Avatar
1. buy the HKS kit
3. have CFT tune it
4. DONE
what hks kit?
Old 02-24-2010, 04:58 PM   #33
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
^ scion xb.....
Old 02-24-2010, 05:01 PM   #34
Tamago
Tamago's Avatar
Drives: ZZW30
what hks kit?
http://www.yarisworld.com/forums/sho...ight=hks+scion
you nailed it sir.
Old 02-24-2010, 05:01 PM   #35
Yoda
Yoda's Avatar
whats the best price you seen it at? cause i am rolling around on 2.5k.
Old 02-24-2010, 05:05 PM   #36
Tamago
Tamago's Avatar
Drives: ZZW30
around that.
you should be rolling on $5000 if you want to set up a $2500 turbo kit.
you nailed it sir.
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 12:59 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-27-2007 12:18 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
