Old 02-22-2010, 06:20 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by cdydjded View Post
The problem is the following, the oil feed is high pressure in, the return is low pressure gravity feed. What is happening since the return is low in the pan it uses the suction of the oil pump to flow oil. When you are accelarating there is no problem, high pressure in, suction through the oil pan. But at low speeds or between shifts there is not enough suction/flow out of the turbo so you get oil creaping through the seals in the turbo. At that give a little puff of smoke through the exhaust. The best way is up high in the top part of the pan. That way the oil will just flow out of the turbo & into the top of the pan above the oil in the pan.
i ran a -8 return line directly into my pan with absolutely no flow problems.. welded a -8 JIC 90deg fitting facing backwards to the "side" of the pan. proper return line sizing is more of an issue than where the oil flows to.
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
