Old 06-20-2010, 07:37 PM   #73
suprajoey
Drives: 08' Yaris
Sweet, thanks so much on the great Thread...!!
suprajoey is offline   Reply With Quote
Old 06-21-2010, 02:20 AM   #74
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Originally Posted by KRAZGRL View Post
I just took some pliers and pulled the badges off. Whatever tape was left I was able to pick off and used goo-gone for the stubborn parts. Really easy.
Hi there! I have this Goo-gone also, but how did you applied it? I've read the directions but maybe you can share how did you apply this goo-gone thing. TIA
rye7jen is offline   Reply With Quote
Old 06-22-2010, 03:41 PM   #75
RedHatch08
Canadetroiter
RedHatch08's Avatar
Drives: 2008 3DR 5M
It's quite easy. Here's what I did:
Just get your Goo Gone and some paper towel. Take 1 sheet and fold it up a few times to make a small square.
Apply some Goo Gone to the paper towel. Wipe it generously across the foam/tape that's left on the car. Coat it well and let it sink in for a minute or two.
Pick an edge to start from, and just use your fingers to start peeling the foam off.
Feel free to re-apply the Goo Gone periodically as you go. It does work better if you give it time to sink in and loosen the adhesive.
Also you may want to do this step at a car wash, like I did.
If you're anything like me, your car will end up with WD-40 and Goo Gone all over the place. After I was done I just gave it a car wash, and it was all nice and clean and debadged.
K&N Air Filter . Rear Debadge
RedHatch08 is offline   Reply With Quote
Old 06-22-2010, 04:33 PM   #76
^1 good instructions, although I use a cloth and not a paper towel.
Using plenty of product is the best advice!
Old 06-22-2010, 04:35 PM   #77
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
added it to the original post
Old 07-12-2010, 06:03 PM   #78
MichaelLC
Nothing to Report
MichaelLC's Avatar
Drives: N/A
Can/should you de-badge an older model?
Looking at getting an '07 and would like to remove the back letters, but think it might be too "baked in" to the paint?
MichaelLC is offline   Reply With Quote
Old 07-12-2010, 07:24 PM   #79
Tylermayer
Tylermayer's Avatar
Drives: 2007 Toyota Yaris
i have an 07 i took mine off and you can tell the difference but once you wax it really good it will look fine!
Tylermayer is offline   Reply With Quote
Old 07-12-2010, 07:47 PM   #80
MichaelLC
Nothing to Report
MichaelLC's Avatar
Drives: N/A
Tylermayer, thanks.
Still have to get one, but I'll give it a try. Waxing will make it go faster too, right?
Old 07-14-2010, 09:41 AM   #81
KRAZGRL
Crazy Girl (Kasey)
KRAZGRL's Avatar
I pretty much did what RedHatch did. :)
Simply squirt some on a paper towel, rub it on the foam that was stubborn and let it soak in. I was able to rub it off with the pad of my fingers and fingernails. Then I wiped down the area with water after to make sure any goo gone residue was gone.
A recent pic:
Old 07-24-2010, 03:05 AM   #82
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Thanks! I already used WD40 to remove the foam tape and it give a nice result too, I might used that "goo-gone" product next for my rear Toyota logo.
Old 08-10-2010, 09:08 AM   #83
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
I have used a generic version of this 3m Pinstriping Remover wheel that I got from my local auto body paint store, I think I paid less than $20.00 for it and have removed countless emblems and even pinstiping on my '91 Caprice with little effort. Well worth it and no paint damage or marring at all. This is what professional people in autobody use to get the residual from emblems/moldings/striping off. This reminds me of a giant eraser [the good kind] that you used back in school. Put it in you cordless drill and your emblem [residual] will be gone in seconds. Take the actual emblem off with fishline first!
Link to a quick Google search.
http://www.yotatech.com/f2/how-pinst...ics-56k-70756/
JTDBT903 is offline   Reply With Quote
Old 10-10-2010, 11:10 PM   #84
.Kevin.
I ain't even mad
.Kevin.'s Avatar
would just WD40 and dentalfloss work for debadging and would it be easy to rebadge it again later
Old 10-15-2010, 01:13 AM   #85
.Kevin.
I ain't even mad
.Kevin.'s Avatar
bump my question still stands, wanna know if wd40 and dental floss will cut it, interested in blacking out yaris and toyota
Old 10-15-2010, 01:19 AM   #86
donchae
noob-toob
donchae's Avatar
Drives: 2007 yaris 4dr sedan
i used heat gun, wd40, and dental floss when i debadged my car.. they worked really well.. i think for the emblems to come off easily, you'd have to use a heat source. i don't know exactly if both just wd40 and dental floss would work just fine.
|| "it's a tough job, but somebody has got to do it" ||
donchae is offline   Reply With Quote
Old 10-15-2010, 02:05 AM   #87
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
I used the heat of the sun and some fishing line to debadge mine. Took 30 seconds per. Dental floss broke on me every time. Besides, it was damned hard to find. People in S. Jesus don't floss...or have teeth! :)
chrisj is offline   Reply With Quote
Old 10-24-2010, 09:21 PM   #88
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
I removed and painted my emblems today but they are not on the car yet Still letting clear coat dry. I purchased the 3M body tape and was wondering if people covered every part of the emblems on the back with the tape or if they only did like the top and bottoms?
Old 10-24-2010, 09:27 PM   #89
Tylermayer
Tylermayer's Avatar
Originally Posted by suprajoey View Post
Hahaha, i read the damm post three time, before i went out side to remove the front and paint it black, but the rear, you say it will leave two holes? so does this mean that the badge is held together by 2 small clips? or is it held together by 2 clips (+) Plus 3M tape?? Dammit, im just thinking of masking everything around it, and sanding/paint the badge on the car, just dont want to mess up my OEM Paint.
Thanks on the Awsome Thread
BTW: Heres mine.
-Not to worry, my little truck is getting lowered this Upcoming week as well..!!
thats what i did
Old 10-24-2010, 10:10 PM   #90
Tylermayer
Tylermayer's Avatar
heres mines
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
revamping the DIY section supmet Suggestions - Feedback - Questions 7 03-23-2009 02:01 AM
