#55 |
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
there will be 2 holes in the back where the big emblem was if you totally debadge
Sold the yaris... rocking an 89 vw cabriolet now :) |
#56 |
![]() ![]() ![]() Drives: . Join Date: Dec 2008
Quick question: For rebadging, has anyone used "3M Plastic Emblem & Trim Adhesive", instead of the "3M Body Molding Tape" that seems to be used pretty often?
Thanks. |
#57 |
§†ęĄ¶‡Ћ-NCP96
A+
#58 |
![]() Drives: yaris Join Date: Jul 2009
yes . i did the same way . but,unluckily,my car got scratch from that .
because i was careless during shaving the emblem :D |
#59 |
![]() Drives: 07' yaris Join Date: Sep 2007
I used a hair dryer to warm them up and then used fishing line to remove. It took a little while to get the excess glue off of the car, but now it looks great.
#60 |
Drives: 2008 Yaris Join Date: Oct 2009
hey guys
greetings from the other side of the pond i recently debadged my yaris but now i changed my mind and want to put the badges back. the thing is though that i dont know their exact position. do you know where can i find it? the guys in the dealership are ridiculous enough to admit that they dont know the exact position of the badges; they will just put them "where it looks ok"... so, i dont want to starting wandering in the streets in search of another yaris, just to measure it, and having people thinking i m a weirdo, thief etc... |
#61 |
resident senior
I would like to add a couple of steps to the painting process .
1. Add a few coats of clear to the newly painted badges . 2. After letting the paint dry/cure for a few days , apply a couple of coats of wax .
#62 |
![]() Drives: yaris Join Date: Jan 2010
how to remove front badge
the instructions are unclear as to how to remove the front emblem , i try sticking my fingers under the grill for the tabs but im not sure what i am looking for as I dont find or feel anything.. can I just use a screwdriver and pry it out by force , if so, am i able to put it back on afterwards
can someone give me clear instructions on how to remove the front emblem, thanks |
#63 |
Canadetroiter
Great FREE Modification
Whoo! My first post at YarisWorld...
Anyways, I just did this mod the other day. Pretty easy and essentially free if you already have fishing line, WD-40, and ... the sun. Looks much cleaner without the badges. Plus it will confuse people even more now. Here in Michigan, lots of people don't know what to make of this car. If it doesn't have a GM/FORD/CHRYSLER badge on it, they think it's a spaceship or something. I've had multiple people approach me in parking lots and ask me what it is. Even with the badges still on it. In any case, I think it's time well spent to do this. I just used the "sun method" (no hair dryer or heat gun), so the hardest part was getting the foam/tape stuff off because it wasn't super hot that day. I just used Goo Gone to help loosen the adhesive. Took a while to get it all off using just my finger nails, but it was worth it. Last edited by RedHatch08; 06-11-2010 at 04:53 PM. |
#64 |
Tiny Giant Clothing
looks great.
its amazing what a difference it makes :)
#65 |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
debadging was the first mod i did.. looks a lot cleaner
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#66 |
Canadetroiter
It was actually my second mod.
First thing I did was get a K&N filter since the paper one that came with the car needed replacing anyways (since I got my Yaris used).
#67 |
![]() ![]() Drives: 08' Yaris Join Date: May 2010
O' Nice, that little red Yaris looks Sexy..!!
-Also Quick question? Did you remove the rear badge to paint it? Or did you mask taped it, and papper it all around to paint it?? -Also how do i remove it to paint it off the car not on it?? Thanks |
#68 |
Tiny Giant Clothing
lol .. read the first post. dont be lazy :)
#69 |
Hahaha, i read the damm post three time, before i went out side to remove the front and paint it black, but the rear, you say it will leave two holes? so does this mean that the badge is held together by 2 small clips? or is it held together by 2 clips (+) Plus 3M tape?? Dammit, im just thinking of masking everything around it, and sanding/paint the badge on the car, just dont want to mess up my OEM Paint.
![]() Thanks on the Awsome Thread BTW: Heres mine. -Not to worry, my little truck is getting lowered this Upcoming week as well..!! ![]() ![]() ![]()
#70 |
Tiny Giant Clothing
the two holes are actually just so the badge is straight. they dont clip in or anything. and its only on the center emblem.
the emblem has two little nubs that fit in the holes. its just for alignment. you wont have to fill anything in or do anything crazy .. just pop it off. you'll see what i mean.
#71 | |
![]() -Thanks so much for your responce, and patience. |
#72 |
Tiny Giant Clothing
Yeah same deal :)
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 02:25 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 12:48 PM |
| revamping the DIY section | supmet | Suggestions - Feedback - Questions | 7 | 03-23-2009 03:01 AM |
